Strut boots on KWs?
Not unless you plan on adjusting them alot. If you plan on setting them and forgetting then you should be fine. I like the STANCE makes their from ALU, instead of steel. Not sure if the KW's are steel or ALU bodies.
Looks like it is a mix (from their website):
Quality:
• Strut housings in inox-line stainless steel technology
• Anodized aluminum spring collars and add-on pieces
• High-quality, high-tensile racing springs
• Special ventilation and sealing system
• High-quality damping components
• Hardened, chromium-plated piston rods
• Special guide and sealing systems
• Pistons with V-shaped Teflon seals – optimal sealing with minimal friction – temperature-resistant, durable damping technology
Quality:
