Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
new GSR clunking over bumps
Old Apr 17, 2009, 08:35 PM
tephra's Avatar
Hi Guys,
First I have rung the dealer so it will be checked ASAP.
But I wanted to get another opinion
Ok so when going over speed humps there is a noise that comes from the front suspension/engine bay.
It basically sounds like a clunk, does it 80% of the time, I have tried to work out if its left or right and I can't tell. Also it does it with the clutch IN OR OUT.. Brakes ON or OFF
Any ideas?
Cheers
D.
Old Apr 17, 2009, 10:11 PM
seven_227's Avatar
+1
My car makes the same sounds when going over speed humps too, the faster I go over the hump the louder the sound gets, but I think it's normal as my friend's GSR makes the same sounds too.
Old Apr 17, 2009, 10:17 PM
jimm's Avatar
mine does not do this. The dealers have forgotten to remove the shipping shims from the suspensions of some who have bought Evos this year. Check to make sure they have been removed.
Old Apr 17, 2009, 10:48 PM
dcpatters's Avatar
Same issue here. I'll check the springs tomorrow. As mentioned, definitely audible if taking the speed bumps with any speed. I usually tend to crawl over them.
Old Apr 17, 2009, 11:10 PM
NsinEvo8's Avatar
Does it do it when your braking, or turning hard. stock shocks/coilovers?
Old Apr 17, 2009, 11:32 PM
tephra's Avatar
got a link to the shipping shim information?
edit - I just had a look at the front springs, nothing in there i'm afraid...
Old Apr 18, 2009, 04:29 AM
markg1018's Avatar
I used to have the same thing, its from the front passenger side. Changed it to coilovers and it was gone.
Old Apr 18, 2009, 05:20 AM
seven_227's Avatar
I believe its from the GSR's suspension as I didn't hear any sounds when I drove an X with Bilsteins.
Old Apr 18, 2009, 08:00 AM
jimm's Avatar
Mine is a GSR and no sounds so not all cars have the issue.
Old Apr 18, 2009, 08:26 AM
ibarkovic's Avatar
gsr and no sounds at all
Old Apr 18, 2009, 08:36 AM
Clipse3GT's Avatar
x2
Old Apr 18, 2009, 08:51 AM
Xtremist's Avatar
Mine does the same thing, only from time to time...
Old Apr 18, 2009, 04:28 PM
BigT's Avatar
Mine does the exact same thing. GSR...
Old Apr 18, 2009, 08:23 PM
slo4g63's Avatar
I have the GSR and it makes the same clunking sounds on the passenger side only. I only notice it on harsh quick bumps.
Old May 17, 2009, 10:27 PM
tephra's Avatar
bit of a bump... (excuse the pun)
so I took the car back to the dealer, they said the ball joint nuts were loose - supposedly tightened them up...
didn't do the alignment as I requested (since they made a change to the suspension)...
still clunks over speed humps or really big bumps..
also its both sides, as i took a bump slightly of centre and I heard two separate noises... seriously considering taking it to a real mechanic who knows evo's - but that will cost real money instead of warranty bollocks...
Quick Reply: new GSR clunking over bumps
