Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Spacer Question
Old Apr 29, 2009 | 09:02 AM
junk1337's Avatar
Spacer Question
I'm getting my car lowered on Eibachs. I think it lowers the car about 1.5 inches.
Would I have any issues running 15mm spacers on all 4 corners? I'm particularly concerned about the back since it has a larger fender lip. Would I need to roll it or would wheels being 15mm closer to the fender not be an issue?
Thanks for your input.
Old Apr 29, 2009 | 09:14 AM
hotstix's Avatar
Im assuming you are running the stock GSR wheels???
Old Apr 29, 2009 | 09:37 AM
junk1337's Avatar
Yes, sorry. I'm on stock GSR wheels.
Old Apr 29, 2009 | 03:26 PM
hotstix's Avatar
Stock GSR wheels are +38 offset. With a 15mm spacer that would make the new offset +23.
From what I have read, 18x8.5 +23 should fit fine without fender modification. If it does happen to rub, a roll would definitely solve the issue, but you should be fine.
Here is a thread for reference
http://www.evoxforums.com/forums/showthread.php?t=10191
