19 by 10 with a 37 offset??? question?
will the tenzo gf7 fit my evo if i roll the fenders??? i called and thows guys are cluelesss they only know regular fitments. . . iv seen really low offsets but nothing like this before,. . .
think about this? it would look sick if it sat the right way but at a 19+10.0+37 offset
ams mbc
agp upper icp
agp lower icp
agp cold are intake
k@N cone filter
UR 02+ downpip
UR test pipe
BUSHURE CAT BACK dual
greddy boost controler
tuned by jestur
dyno'ed at 360hp 380 tq at 28psi
yes i know this car was built on a wensday.
ams mbc
agp upper icp
agp lower icp
agp cold are intake
k@N cone filter
UR 02+ downpip
UR test pipe
tuned by jestur
well, put it this way, people are putting 19x10 25mm offset....
With those, I dont think you're gonna get the look you're trying to achieve. at +37, the wheel is actually gonna be "sinked" in. From the looks of the style, you might have problems clearing the Brembos in the front and may need a spacer to push it back out. Stock offset on stock Enkeis is +38...
IE 9" wide rim with +15 offset will sit closer to the outside fender (more flush...etc) than a 9" rim with +35 offset
19x9.5" 35mm offset and I had 4-5mm clearance to the inner suspension on the front. Your wheels are .5" wider or .25" wider each direction from centerline, that alone is pushing you 6mm inwards and outwards which puts you at -1 to -2mm clearance. Add in 2mm more for 37mm offset and you are at -3 to -4mm clearance. You will need to use a 10mm spacer to get back to 27mm offset which will be around 6-7mm of clearance which could vary depending on tire choice. In general I would avoid using spacers if you can as they can add another element of uncertainty especially if you get any wheel vibration. That's not something you want to feel if you track the car at road courses at all.
importdps
Evo 'For Sale' Wheels / Tires
17
Jan 12, 2010 08:05 AM
demonblackevo69
51
Sep 14, 2008 04:05 PM
