In the middle of front sway bar install - need help
Got the new Hotchkis bar installed today and I've got pretty much everything done except one crucial last step. Instructions said to disconnect steering shaft which I did to help lower subframe to get the old bar out and the new one in. Now, I can't reconnect the steering wheel shaft to the power steering shaft.
Even though I've got the subframe bolted up tight, the steering wheel shaft and the power steering shaft barely mate up with one another. It seems like the power steer shaft needs to stick up higher. (Damn, it sounds like they are having sex). The car is still up jack stands. I haven't tried putting on the tires and lowering the car. I don't know if that would make a difference.
Any suggestions?
Any suggestions?
I was able to connect the steering shaft. I kept getting the two pieces just barely together with the steering shaft about 1/3 of inch inside the power steering shaft. I thought it was because the subframe wasn't in the correct position. I had the shaft in a 1/3 of inch and this time I used a screwdriver and hammered down on the top shaft. It slipped in all the way in. Just had to use some force
Ah thanks for the update, I was considering a front bar at one time but it looked like a pita to install and I didn't want to wreck my alignment. It's possible it would have lined up closer if you took the weight off the front wheels since they droop down about 5" when off the ground.
Now that I've done it, it's not that hard. Just a lot of bolts to loosen and tighten, and most of the time is spent under the car.
I've come across posts from EVO X owners who didn't disconnect the steering column and lowered their subframe to gain enough clearance to remove their stock bar and install their new larger bar. I wish I had gone that route. Here is some advise I got from an EVO X owner about disconnecting the steering column for a front swaybar install.
"Did you resolve this yet? I think I know what happened if you haven't. The part of the shaft that is connected with the steering wheel behind the dash is a 2-piece shaft. It has 2 sections sleeved into each other with an external and internal spline. When you put the subframe back up you pushed these 2 parts of the shaft together and didn't know it. With the subframe in place, you need to look up behind the dash at the shaft. There's a simple external band clamp you'll need to squeeze at the spline junction, then you can pull the lower portion of the shaft out the spline some to meet up with the steering rack at the bottom. A pair of vice grips on that clamp will make it easier."
That wasn't in the Hotchkis instructions. I called Hotchkis today and their customer service rep said if you just yank down on the steering column hard enough it will extend. I was tugging down with all my might. It took a hammer on the end of screw driver to get it into place. Wish I had known about the technique mentioned above.
EVOlutionary
19
Oct 1, 2006 05:54 PM
