Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
What pads are you using
Old Oct 7, 2009 | 07:16 AM
CatalystGod's Avatar
Ferodo DS2500 on Girodisc 1 piece slotted all way around with girodisc anti noise shims. no squeaking sound issues yet. So much cheaper than stock.
Old Oct 7, 2009 | 01:32 PM
EndlessRed's Avatar
Originally Posted by goofygrin
HPS pads aren't that great. Ask SmikeEvo on his thoughts about them. The HP+ is a better street pad.
The X is HEAVY. You need a better pad.
of course hp+ is a better pad. it's not even made for street. it's dustier too, which is a deal breaker for me unfortunately. if i wanted dust i could have sticked with the stock pads.
Old Oct 7, 2009 | 04:58 PM
jeromski2003's Avatar
Kotex pads
Old Oct 8, 2009 | 11:08 PM
skylinegtr35's Avatar
Endless MX72
Old Oct 9, 2009 | 04:46 PM
m0nkie's Avatar
Are the Ferodo DS2500 good for the track/auto x evos or good for DDs too?
Old Oct 9, 2009 | 08:26 PM
On the street I do not see any difference from the stock pads (also ferodos BTW). I am yet to autocross/track. The DS2500 is the middleground pad. The 3500 is for track only and lousy for DD. the 2500 is designed for people who want to avoid pad changes whenever they need the performance. People more particular abt racing performance usually run a street setup with cheaper pads, and swap them out for high performance when on the track. With the 2500, you can avoid this.
Old Oct 9, 2009 | 08:37 PM
goofygrin's Avatar
The 2500 is only a track pad if you don't push the car. If you're going to be tracking hard or frequently you WILL need a dedicated track pad... the X is simply too heavy otherwise.
I now because I cooked the hell out of a set of DS2500's
Old Oct 10, 2009 | 12:28 AM
m0nkie's Avatar
well... my stock pads are going out.. Im not sure which set to go for.. the stock ones cost 240 total
Old Oct 10, 2009 | 12:39 AM
Goofy, you're using the ST43 now right?
Old Oct 10, 2009 | 05:25 AM
seven_227's Avatar
Changed to Ferodo DS2500, and to my surprise the stock pads were also stamped with Ferodo logo as well! Didn't know that mitsu used Ferodo pads.
Old Oct 10, 2009 | 11:04 AM
m0nkie's Avatar
where do u guys get Ferodo pads? n what price??? whats the mileage on ur car when u switched?
Old Oct 10, 2009 | 08:56 PM
Got mine from Girodisc. I had 19,000 miles on mine and stock pads were worn out about 3/5th of the thickness compared to the DS2500.
Old Oct 11, 2009 | 12:56 AM
m0nkie's Avatar
k.. im at 20k and my brake lights are tossing on crazy...
Old Oct 11, 2009 | 11:07 AM
spoolme's Avatar
so many of same threads...
Id suggest Endless Ns97 that i have now. Low dust or noise. Great stopping power, using for daily/autoX
Old Oct 11, 2009 | 11:24 AM
raytrix's Avatar
tell uxs where you got them from so people can start buying them and give more comment on them endless. I see more hawks pads being advertised for sale than endless.
