Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
wheel spacers and recomendations
Old Feb 1, 2010 | 02:36 PM
EVOXGEO's Avatar
wheel spacers any recomendations
I was thinkin about puttin wheel spacers on my evo x with the stock wheels, I wanted to know if anyone was runnin spacers and if u guys had pics to show off thnx guys
Old Feb 1, 2010 | 03:04 PM
love67's Avatar
IMO, 20mm is the best looking
Old Feb 1, 2010 | 03:54 PM
lowkey's Avatar
Registered User
https://www.evolutionm.net/forums/ev...r-specs-7.html
Found it via the search button and using spacers as the keyword. Just saying...
Old Feb 1, 2010 | 05:12 PM
InjectedPerformance's Avatar
just make sure you run longer studs and don't run the spacers that have studs built in
Old Feb 1, 2010 | 05:58 PM
jimm's Avatar
Disagree....
Longer studs only mean you are riding on the studs...they are not designed to do this. You have two shear planes of force and are asking for broken studs and unfortunate moments afterward when the wheel goes its own way and you and your car with 3 wheels go another.
What you want is a spacer that effectively acts as a hub extention. To do this you need quality spacers wtih their own studs AND hubs so that the wheel is centered and rests on the hub. YOu want good quality materials so Project Kics (what I run) and H and R are good brands.
I have 20 mm on stock GSR wheels with my snow tires...I will try and post a pict (although the car will be dirty from the 80 tons of salt they put on the roads every time it snows 1/2 inch.)
Old Feb 1, 2010 | 05:59 PM
lowkey's Avatar
Registered User
Ok, now this is a new take, most posts on this board said exactly the opposite. Why?
Old Feb 1, 2010 | 06:35 PM
I should have been clearer, I apologize, you for sure want hub-centric spacers, which is typically only offered on higher quality brands... the reason I stated against the typical spacers that have the studs built in is because unless you go with a high quality brand they are prone to shearing (a lot of consumers will buy the cheap ebay ones to save money which result in similar disaster stories as stated above) ... the other problem is that if the spacer isn't wide enough to compensate for the factory lugs extension then you have to be careful what wheel you put on there... I agree H&R and Project Kics are both quality though and as long as they are model specific then you should be fine
Old Feb 2, 2010 | 09:10 AM
p.phresh's Avatar
Lowered on Eibach Pro Springs, with Sparco hubcentric 20mm spacers and extended studs.
Slight rub to the fender vents in front at full lock. Wheels do feel heavier since the added weight of the spacer adds to the weight of the hub which translates into increased rotational mass, so you'll feel like there's less torque and power than running without spacers.
Old Feb 2, 2010 | 09:18 AM
p.phresh's Avatar
oh i also want to add:
If you intend on using extended studs you will have to run tuner lugs or open ended lugs.
Installing the extended studs are easy up front, you can just leave the hubs on the car and just hammer in the studs to get them started and then pull them through with a nut and an impact wrench. However, the rear hubs have to come off the car to get the studs through since the dust shield prevents you from accessing the stud holes in the rear.
Old Feb 2, 2010 | 11:28 AM
EVOXGEO's Avatar
Originally Posted by jimm
Disagree....
I would like to see if u can post up ur pics man , thanx
Old Feb 2, 2010 | 01:15 PM
EVOXGEO's Avatar
Thanks for the pics guys
tweakdsm
May 26, 2017 10:33 PM
poonpower
Oct 22, 2016 06:35 PM
Jonno99
Sep 10, 2015 11:45 PM
wowzers
Nov 3, 2014 08:50 AM
mitsuevodriver
May 8, 2010 08:55 PM
