knocking noise front left?
Anyone has this issue while turning or stright at slow speed (1 to 20ish kmh ), there is a metal knocking sound coming from the front wheel axle like something loose?
just suddenly happend, i changed my springs a month ago eibach prokit, and put the eibach bolts for the alignment , im at 1.3 all around
Hope that someone can share some experience.
( brought it to the dealers they checked and found nothing reasons ...lol ... it didnt fit on there lift....)
so right now the wheel is off ....and everything seems tight top 3 bolts,top shock bolt,2 bottom one pads seem fine changed those 2 moths ago (ceramic hawks)
4 months ago the same side as the sound driver side table was changed
omfg,
alright so my stepfather tells me maybe its your tire that is blown from driving over a hole i was like nahhhh lol....
so i was looking at the plastiks and alot of my plasik pins were out/missing
so i replaced all of them ....
guess what .....
went for a little ride no more knocking ..... ill post tmw after i drive a little more
guess what .....
alright its still doing it, its $%^&$% pissing me off ahhh dealler cant find the problem ,
im getting both tables chaNged and see whats going on tmw afternoon
so i just came back from the dealler with no luck .... one of the tables was changed ...
so the sound is still there ...
when i got i got 2 bolts from eibach to inline it better( so they said and keep the inline better)
so i was inspecting my car like i always do when its on a lift and i notice that the side that makes the most racket(noise) had the bolt ( ebaich ) and the other side still had the stock ones on
WHAT THE %^&* !!!???
i called the place that did my alignment but there closed until the 8th of march .....
( i was told that, that place was the best in montreal...... anyways)
ok after i tripled checked , its still doing it after i got reinlined !!! and checked again!
same noise but now its moved to both sides
does anyone have the eibach springs on there mr ??? and problems ie noise lol
