Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Installed Swift lowering spring/ having problems
Old Apr 28, 2010 | 01:20 AM
markpaco's Avatar
Like the others posted above, toe is what will wear out the inside of a tire fast. Camber does little.
You actually didn't gain much camber in front from lowering it due to the Macpherson struts.
I'm actually surprised that you added positive camber after lowering your car. Why did you do that? Zeroing out the toe would have decreased inner tire wear significantly while maximizing negative camber would benefit handling with negligible tire wear.
tsi90awd
76
Dec 29, 2011 11:15 PM
m0nkie
Nov 6, 2011 05:10 PM
WRC-LVR
Apr 9, 2011 05:00 AM
damie45
19
Jun 21, 2009 08:09 AM
iodine23
Apr 12, 2004 08:55 PM
