Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Another Brake Noise Thread - HELP
Old May 4, 2010 | 04:30 PM
Silver06evo9mr's Avatar
Just installed Gyrodics Magic pads. Everything feels good but the rear brakes are squeeling terriblly. Only really does it at low speeds. I sprayed WD-40 on them and it worked for first couple of stops then started again. Im thinking it is becasue of the adapters they include for these. Anything I can do to make it stop? Tried searching didnt find anything specific to these.
Thanks
Old May 4, 2010 | 04:43 PM
evogeo's Avatar
im pretty sure its the adaptors ive tried lots of things.. the rear is all i hear.. I sorta got used to it hahah i either brake hard so it wont make noise or i start braking super early applying the brake pedal at a point where there is no squeeking.. people who dont know always tell me "you need new brakes" i say "THEY ARE new " hahha
I gave up on them im just gonna change them out when i get some extra cash and buy some without adaptors.. like project mu
Old May 4, 2010 | 05:02 PM
i called martin at GD, he said they arnt supposed to squeek. gunna give them 50 miles or so, then if they still squeel then im gunna take apart and add some lube to them on all sides.
Old May 7, 2010 | 06:50 AM
bump
Old May 7, 2010 | 07:24 AM
EngRWW33's Avatar
WD-40 will just burn off. Lube should do the trick since it is most likely just some vibrations causing the noise.
Smike
Jul 16, 2017 02:00 PM
P_A_STREET_EVO8
Jan 20, 2006 08:03 AM
JuniorRSX!
Dec 11, 2005 10:26 PM
my3000gt
24
Oct 23, 2005 05:11 PM
bluepeartype-s
Jul 26, 2004 10:27 AM
