Suspention creeking
I am having a similar problem with my 05 evo 8 mr. It sounds like a creaky door kinda. I have been searching around and it seems like people are having to replace the bilstiens in the mr versions and newer evos. Do you guys think they could be the problem. Thanks for the input.
kk il try that out tomorrow. but one quick question.. the sway bar bushings... is that just the bolts that hold the sway bar on? or what? help me out here
that sucks dude. your prolly having the same problem because my problem happened because of the drop and the sway bar is the source.. check it out.
i dont think that is the problem. i think that the sway bar bushings need to be greased. if what u said is the problem then handling would be effected in a negative way and it isnt.. either way im going to go to the shop were my springs were installed and have them look at it
Ya mine is doing sumthing sim. But now it pops about 15 Check tarmac lights a day but goes away within 5 sec of them coming on. I am just gunna take it into a shop to see if they can figure it out. I took it to the dealer and they didnt no what the hell was causing it. Dealers sux.
