Suspention creeking
Suspention creeking
there is a creeking noise coming from what i believe is my suspention, its iratating and makes my car sound like crap. the noise happens at low speed when i go over a speed bump, uneven road, incline or any other situation that the shocks compress. im running stock suspension except for tanabe DF210 springs. i got an alignment 2 weeks after i got my springs installed back in late march.. here are my alignment specs if it helps
Is this sound coming from the front or the back? also how much did the springs lower the car? and have you checked your rear sway bar? sometimes dropping a car will make the end links rub against the chassis but you said you got an alignment they should have noticed something like that. are you rubbing at all with your Matte Bronze Rota Grids 18x 9.5 + 20?
Is this sound coming from the front or the back? also how much did the springs lower the car? and have you checked your rear sway bar? sometimes dropping a car will make the end links rub against the body but you said you got an alignment the shouldve noticed something like that hmmmmm
I would jack your front end up and make sure your springs are perched right and if there is any sign of oil around the wheel well, also make sure there is not any debris like acorns rocks stuck in the springs. Hey you did not mention but did this happen before or after the alignment?
well at 13k, chance of blown shocks are slim unless you've tracked it (then anything is possible). best way to check for blown seal in shocks is move the dust cover and check for oil
