Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
coilover poppy sound!
Old Aug 19, 2010, 05:17 PM
RedEvoxGSR's Avatar
ok after i got done autoXing i have noticed my front and noticeably my right front coilover has been making poppy sounds.. it really does it when i turn the wheels left/right.. i've checked everything and its all tight and nothings loose.. i have no idea what i could be!! its def the spring making the noise.. well thats what it sounds like but its def a poppy sound!
ok after listening to it again its kinda more of a ping ping ping sound!! does it at slow speeds and if im jus parked and i turn my wheels!! going at cruising speeds u dnt hear it!
Old Aug 19, 2010, 05:24 PM
raytrix's Avatar
pillow ball mount noise is common
Old Aug 19, 2010, 05:27 PM
RedEvoxGSR's Avatar
so how do i fix it? its annoying and bugs me!
Old Aug 19, 2010, 05:34 PM
smithrcing17's Avatar
does it sound like a bang everytime you turn sharp or hit a bump?? mine did the same exact thing, the nut on the top of the coilover right below the damper adjustment got loose on mine somehow but as soon as i snugged it up it was perfect! hope that helps
Old Aug 19, 2010, 05:40 PM
RedEvoxGSR's Avatar
thats happened to me before!! i know that sound and its not that at all!! i wish it was so i knew how to fix it! this is like a popping sound from the springs, from what i can describe!
Old Aug 19, 2010, 05:54 PM
did the actual spring come loose? i dont really know how it could unless the two set nut plate things on the coilover vibrated loose
Old Aug 19, 2010, 06:20 PM
RedEvoxGSR's Avatar
hmmm when i checked everything nothing was ever loose so dont know how the spring would be loose but i'll have to check that out tomorrow
Old Aug 19, 2010, 06:34 PM
did you take weight off the car? you need to put it up on jack stands so that the coilover wouldnt be compressed and if the spring was loose it should move around like if you hit a bump it would compress and decompress real fast and maybe you could hear the spring move around. idk just throwin some ideas out haha
Old Aug 20, 2010, 03:45 AM
RedEvoxGSR's Avatar
ok sounds more of ping ping ping sound at low speeds!! really hear it when im parked and i jus turn the wheels left n right
Old Aug 20, 2010, 08:18 AM
GTWORX.com's Avatar
it's the spring binding....it's trying to turn in the perches when you turn the wheel at low speeds and it binds and the pop is when it releases. grease the spring perches, get a thrust sheet, or get a torrington bearing.
- drew
Old Aug 20, 2010, 08:31 AM
DaveGSR's Avatar
- drew
^this.
Old Aug 20, 2010, 02:11 PM
RedEvoxGSR's Avatar
- drew
im a newb on all this so i have no idea how or wat ur talking about
Old Aug 20, 2010, 03:56 PM
EVOsoFRESH's Avatar
Dude I'm having the same problem. So its possibly the pillow ball mount? I think that might be the problem sometimes I even get it when i turn while going up a curb.
Old Aug 20, 2010, 08:04 PM
RedEvoxGSR's Avatar
well i will do wat gtwork is telling me i jus dnt know whats hes talking bout snd we will c if that works!
Old Aug 23, 2010, 09:50 AM
DaveGSR's Avatar
how and why do you guys buy coilovers and not know how to use/maintain them?
grease the spring perches is too hard to understand? sell your car.
Quick Reply: coilover poppy sound!
