how long our stock Yokohama Advan tires last?
i now have 8500 miles on them, normal with some spirit driving, no tracking. so far the threads on the tires are still pretty decent. how long before you change out your stock tires?
they are very soft compound from the factory....don't expect to last more than 15k, honestly....the only way you will see more than that is, if you get tire rotations every 3k and drive like a grandma
but under normal "Evo" driving conditions, you are looking at 15k or below
I replaced mine @around 11k. Started to hydroplane, tramlined and got really loud. Mine looked fine at around your mileage then went downhill fast. Make sure you check the inner treadwear, that's where mine were shot.
Hi if you don't mind me asking where did you get that number, as I am looking for sources which state how long the stock tire *should* last. The tire is rated for 180, however thats useless to estimate mileage unless I now the baseline they're using.
cheers
