Evo X RS brakes vs. Evo X brakes vs. lancer GTS brakes ??
Can anyone tell me where to find a definitive answer on my question at the end of this thread?:
https://www.evolutionm.net/forums/ev...ly-brakes.html
Starting a new thread since it's really a different topic. Basically what I want is an OEM caliper that will let me run a 15" wheel on an Evo X. the JDM RS came with smaller calipers and rotors and 16" wheels (which may or may not be the same as the lancer GTS). That said, I've always heard that GTS brakes are not compatible with Evo brakes. Can somebody let me know what the deal is here?
I'd like 15s for ice racing, so stopping power and heat is a non-issue. 16" wheels would be the next best thing.
Thanks.
Thanks.
Thanks.
Thanks.
The X RS brakes are the regular lancer GTS ones before the older evos. They might got an extra set up for the new platform but i doubt it, either way it would be a garbige for racing, even for light racing. Unless its drag racing ... LOL.
To fit 15's to the X GSR is a *****. We worked on it 1 year when finally find a solution. Unless you will get the grupe N brakes for gravel around $8k . The "cheap" and also good way is still not that cheap. We got the AMS - WIlwood front kit and we have a Frankenstein set up in making for a rear. Makes it even harder the old evos brakes are not fit on the new chasiss , unlike before.
So its a whole mess , but if you need a set up we can do it for you or you go to Buffom who build L'astage car. But that will cost you a lot.
Rob
Ice racing doesn't require much of the braking system IMO. Almost every STi downgrades to a lower-end Impreza brakes in order to run smaller tires. That said, 16 maybe fine as there are some very good 10/65-16 ice tires out there. Looks like I'm going to be stuck on 18s again this season though. Once the car gets a little older I might start thinking more seriously about dirt rallying and a good 15" wheelset / brakes.
I used to travel on brakes in snow racing gives me better confidence and control. But a same time it is a cold eviroment so the break hardly get burned. Also that way i kepp my pads hot so they grip more better or predictalbe for me. But you right you do not need that strong clamp in ice.
In the other hand the 15's would be great since you can get a sameller profile tires with higher wall, and 15's are cheaper. Dont forget the 18's you cant ride even 50 high tires. You need at last 55 or 60 hight and for race i would run around 205 or 195 's with or withut studs. Depends on the rules of the race.
The 15's wheel dont need super strong brakes we do also cheapos on the rear. and wilwood /also cheap for the front. Only thing we need to modify to the rear to accept the new calippers. SO the brakets are in a making. After that is an easy swap from the brembos /for tarmac/ to the gravel snow dirt set up.
More info is in pm if you interested. Also would be HUGHE if you could disable the ABS on snow and ice. That is also we can help.
Good luck for a season and enjoy the winter
Rob
This is a great thread with a lot of good information. I'm planning on going with a gravel/snow tire setup like this. Once I have the Wilwood front setup and get the rears sorted out, will I lose ABS? Also, any suggestions on what wheel to go with?
Robevo RS, you have a pm
Silverton
May 4, 2016 11:07 AM
evoatcha
May 3, 2009 07:30 PM
YeOldeLancer
Nov 14, 2008 01:11 PM
chet
16
Oct 16, 2007 02:28 PM
Tachyonzero
11
Mar 24, 2007 08:51 AM
