Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Motive speedbleeder
Old Feb 20, 2011 | 08:01 AM
Mr. Move's Avatar
Motive speedbleeder
Im looking to buy a motive speed bleeder but i don't know which adapter to get for the single bleeder does anyone have one of these?
here are the choices.
http://store.motiveproducts.com/sing...eders-c16.aspx
Old Feb 20, 2011 | 08:21 AM
milford's Avatar
0107
Old Feb 20, 2011 | 08:23 AM
cfdfireman1's Avatar
pretty sure you need the 0107 Ford adapter, works for the VIII and IX.
Old Feb 20, 2011 | 08:26 AM
milford's Avatar
i used mine for the first time last week. absolutely amazing. bled all 4 brakes and my clutch in less then a half hour.
Old Feb 20, 2011 | 01:25 PM
Only bad thing about this system is that it supposedly forces moisture into the fluid. I have an idea about a way to add a diaphragm to it.
Old Mar 1, 2011 | 03:11 PM
Mr. Move's Avatar
i got my speedbleeder and the ford 3 prong doesn't lock onto the Evo 10's brke fluid tank am i doing it wrong has anyone used these on an evo 10?
Old May 7, 2011 | 11:55 AM
Yoo Shin's Avatar
Bump, I want to know to before I order one. Mr. Move you got the 0107?
Old May 8, 2011 | 11:26 AM
Red Dragon's Avatar
Anyone tried Phoenix System?
http://www.brakebleeder.com/
Old May 10, 2011 | 08:32 AM
linjy2's Avatar
Im interested also. I bought one universal one that does not fit. Waiting on more opinions before i go buy the adaptor for mine.
Old May 10, 2011 | 09:27 AM
mlomker's Avatar
The 0107 works but it takes patience to line it up and get it on securely. You definitely want shop towels handy when using them.
Old May 12, 2011 | 10:37 AM
MR Dan's Avatar
Yea I have the Ford one too. It takes some time to align the adapter properly for it to fit.
Old Oct 8, 2011 | 09:56 AM
Yoo Shin's Avatar
Just got mine and will be doing my pads and bleeding tomorrow. I'll keep that in mind.
Also keep reading conficting comments regarding which to do first, bleed or replace pads? On my WRXs in the past, I've always done the pads first, then blead.
Old Oct 10, 2011 | 04:26 PM
journeymansteve's Avatar
Well, that's cause it's hard to answer. the PERFECT way would be to bleed, change, and bleed some more. The fluid that's at the end of the system is dirty and needs to travel out, never in.
WHen you change, the new pads will be thicker than the old ones, 100% of the time. So that means that to fit them in the same place, you need to open them up. That's done, most commonly, by opening the reservoir and pushing the calipers open a bit (by hand, screwdriver, or special caliper spreading tool -- love mine).
You "can" open the bleeder valve and then spread and let the bleeder's push that out. That's a handful without letting tons of air into the system that then has to be bleed for certain. That's not my cuppo tea.
I'd recommend using the judgement of "how long has it been since my last flush?" drive the approach. If you flush between pad changes, so for HPDE's, you shouldn't worry and I usually install pads first and then flush.
But if you don't flush fluid regularly (firstly, begin doing so, performance and longevity of your calipers), you should flush before doing anything that changes the position of your caliper pistons. The deal there is that you flush, you change/fill fluid, you later overflow the reservoir when spreading, making room for the new pads by compressing the pistons. When you flush, the tools usually all get you to a "full" level, but with worn pads, that's too much fluid.
NOTE: you can't open the caliper pistons up AFTER you flush by using the external bleeder screw, you'll let air in.
Old Oct 16, 2011 | 09:17 AM
Swiss's Avatar
Slightly off topic, but if you’re still considering which bleeder to buy, I’d suggest looking at “Speedbleeders”
http://www.speedbleeder.com/
One way check valve, that way all of the old fluid (including when you’re pushing pistons in for new pads) is going “out” not back into the system. Have used them on two cars now, work great, makes bleeding a one man operation that I can do at the track. Note; you just want to open them a quarter turn or so, not full rotation (otherwise you may get some air leakage around the threads).
Old Oct 16, 2011 | 09:27 AM
Yoo Shin's Avatar
Thanks, good stuff. I used the Motive bleeder with 107 attachement, had no issues with it fitting, but the brass connection between the attachment and the pump leaked a bit.
I did open up the bleeders before taking the pads out, and even with the littlest movement, fluid would come out so it's very pressure sensitive. I awhere in. Most of the air came from the rear inners.
Anyways, the brakes are fantastic feeling, better than new!
jimbo74
13
Aug 29, 2016 09:25 AM
rob_d
27
May 2, 2016 09:23 PM
TommiM
Feb 9, 2014 12:28 PM
doug davis
Nov 30, 2010 07:23 AM
ak47po
Oct 21, 2009 09:52 AM
