20mm wheel spacers
However with about 4 ppl in the car going highway speeds and go over a large dip - you get a very very light rub on the fender liner.
stock wheels with 20mm spacers put them at an offset of +18 so your wheels with spacers will be pretty far out and will def rub in the back, maybe the front depended on your suspension set up. stock suspension won't be a prob but i doubt anyone here is using that
Same here. It is just barely rubbing the fender liner when in reverse with the wheel clocked all the way to the right (Steering wheel Clockwise). If I can figure out a way to just pull the liner in about 1.5mm, then it would not rub at all.
Oh, and I have a 2014 MR with 20MM spacers on stock wheels with stock springs.
-Jeff
