Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
roll center kit question
Old Jul 5, 2011 | 09:51 AM
redmachine's Avatar
Hey guys, those who have the whiteline roll center kit installed... Is your steering much heavier? After installing it i feel its much, much heavier. Is this normal?
Old Jul 5, 2011 | 09:57 AM
sgtr275's Avatar
Did you have an alignment done?
Old Jul 5, 2011 | 10:16 AM
KyleH's Avatar
I noticed no noticeable change. Mine's not a daily, so it could be there and I just didn't notice. As mentioned above - assume you had an alignment done? If not, you'll need to.
Old Jul 5, 2011 | 01:10 PM
Phantom09's Avatar
i did not notice any BIG change. maybe a slight change. i noticed my steering got heavy after i installed dunlop star spec tires.
Old Jul 6, 2011 | 05:04 AM
redmachine's Avatar
yes i had an alighnment done... 2.0 front 1.5 rear and 0 toe... maybe as i have a slight rake due to the front being a little lower than the rear at the coilovers?
Old Jul 6, 2011 | 09:55 AM
SniperwolF's Avatar
mine feel much smooter .. much better steering .. didnt feel any worst than the oem feel .. it actually makes my car steering fell way better ... any recent mods beside rck ? bigger or wider tires?
Old Jul 7, 2011 | 06:36 AM
redmachine's Avatar
No recent mods.. Was already on 9.5 inch te37's with 265 nitto 05 tires
Old Jul 7, 2011 | 11:15 AM
skyseer's Avatar
I installed Whiteline RCK and Front LCA Bushings at a same time. Noticed that steering became a little heavier.
Old Jul 7, 2011 | 11:22 AM
WW-GSR's Avatar
Did you bump up negative camber to -2 degrees after installing the RCA kit, or was is at the same setting before?
ogrenator
May 29, 2014 08:10 AM
brenner
Apr 14, 2011 04:17 PM
sum0325
10
Aug 18, 2010 10:58 PM
freshevo8
Aug 20, 2005 04:15 PM
JT-KGY
Jul 18, 2003 10:01 PM
