WORK Brombacher **Special Edition**
Subscribe
Jul 25, 2011 | 03:39 PM
The WORK Brombacher Special Edition is back and available in 19" 5x114.3 bolt patterns!
Typically the Brombacher 19" with a Step Rim was reserved and intended for Porsche 5x130 applications only, but WORK went ahead and had center disk quantities made in order to achieve 5x120 and 5x114.3. The first run sold out quickly, and this is the second run which should sell equally as fast!
Standard colors are Feinheit Silver II (FS2) & Matte Black (MBL) Finish.
Special colors available, please inquire with your sales representative for availability.
Technical notes:
This special edition Brombacher has a different center cap and center bore size compared to the Brombacher Porsche version. The 5-114.3 PCD will have a center bore size of 73.3mm.
The Brombacher 19” step lip brake clearance may pose some issue with newer vehicle with larger size brake system. Please double check with us regarding brake clearance. See the attached file regarding brake notes for more details.
Thank you for your continued support of WORK Wheels!
Reply 0
Jul 25, 2011 | 03:45 PM
wow! very nice wheels, i need to run out and buy an X for these. brb.
Reply 0
Jul 25, 2011 | 03:55 PM
Nice wheels. What offsets do they have for an Evo X?
Reply 0
Jul 25, 2011 | 05:19 PM
Offsets range from +65 to -4.
On the Evos, you do have to run a spacer to clear the front brakes. Rear brakes clear no problem. The Evo 8/9 need a 12mm spacer, while the 10 needs a 17mm.
With that in mind, we can easily calculate what offset you'd need based on your width. For example, if you wanted a 19x10.5, I'd go with the +40 offset. Once you add the 17mm spacer, you'd effectively have a +23 offset which looks good imo.
Reply 0
Jul 27, 2011 | 11:26 AM
so for 8/9s that want to run 18x9.5... what offset would be the suggested one... +31? this would give you a 62mm lip. Just curious how much are for a set of these bad boys and what is the difference between these and the VS-XX...? Well other than color of wheel
Reply 0
Jul 27, 2011 | 12:19 PM
what would be the best offset to get front and rear for a 19x10,
Reply 0
Jul 27, 2011 | 02:09 PM
Quote: so for 8/9s that want to run 18x9.5... what offset would be the suggested one... +31? this would give you a 62mm lip. Just curious how much are for a set of these bad boys and what is the difference between these and the VS-XX...? Well other than color of wheel
The Brombacher is only available in 19" diameter for the 5x114.3 PCD, As far as difference between these and the VS-XX, it's mainly the design of the face that's slightly different. Particularly where the bolts are. If you wanted to do a 19x9.5, then I'd say the +27 offset on the front is good for a stock body 8/9. Once you add the spacers to clear the brakes, you'll be at +15 which looks great. Check these pics for an 18x9.5 +15. On the rear, no spacers are needed, so you can order the 19x9.5 +15.
http://rimtuck.com/setup.php?id=1196
Quote: what would be the best offset to get front and rear for a 19x10,
For an Evo X, I'd suggest ordering the +46 in the front, which would put you at a +29 after the required 17mm spacer. For the rear, You could do +34 or +21, depending on how low you want to go, and how much camber you want to run. No spacers are needed for the rears.
Reply 0
Jul 27, 2011 | 09:26 PM
what is the price range on these? my friend picked up a set the first run for his IS350 and he spent a good amount.
Reply 0
Jul 28, 2011 | 01:14 AM
Nice looking wheels!
Reply 0
Aug 8, 2011 | 10:58 AM
Does VividRacing carry anymore of the special edition Brombacher?
Reply 0
Aug 11, 2011 | 09:54 AM
Maybe some pricing on a 19x10? I'm not trying to modify my fenders.
Reply 0
Aug 11, 2011 | 10:00 AM
These look sick. I can def. see these on a BMW though.
Reply 0
Aug 23, 2011 | 04:35 PM
thanks guys there are only a few sets left
Reply 0
Aug 23, 2011 | 06:13 PM
damn these are my type of wheels. Def need to remember these when i go rim shopping
Reply 0
Aug 25, 2011 | 05:21 PM
for sure
hopefully there are some left
Reply 0
