Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Lower or no Lower
Old Aug 17, 2011 | 04:26 AM
FJF's Avatar
FJF
Originally Posted by h4ckluserr
While it is true that we all bought an AWD rally-inspired beast, The reality as I've noticed it is that maybe 1%, at a high estimate, actually see any rally time. I'm sure there are hundreds of people, I'd guess even the OP, that drive only one the street. an important detail, because assuming we all only see cement, there are ways to reign the handling in on the Evo. These things of course will be at the expense of the offfroad capabilities of our cars.
I personally will be lowering my car on a set of KW Variant 2 Coilovers, however not to the "rolled fenders are required" on stock tires low. I agree with the OP that I don't like the height/roll of the car. that 1 to 1.5 inches will make a huge difference in looks, while providing increased handling for my tarmac only driving style.
<sigh> I mentioned "AWD, rally-inspired" to explain why the struts are visible (ie. the cut of the fenders). Yes, 1-1.5" lower can make a huge difference in looks just as it makes a huge difference in the geometry of the suspension. Good luck with the increased handling, whatever that means.
Old Aug 17, 2011 | 05:49 AM
justin81's Avatar
get the eibach prokit and your rota grids and roll the rears and buy a set of 265/35 or 275/35 you will be fine. If you put wide wheels and tires on your stock height car it's going to look like a monster truck.
Either drop it on wide wheels, or keep it all stock including wheels.
Old Aug 17, 2011 | 01:16 PM
mindovaanything's Avatar
Originally Posted by Frankiago
Hey, you can keep your stock springs and get the exact look you're going for:
http://www.034motorsport.com/chassis...t-p-21602.html
Price is pretty steep, but well worth it IMHO. Mine's in the mail, or so I'm told.
I laughed so hard reading this
Old Aug 17, 2011 | 05:58 PM
deludedbuzz's Avatar
Old Aug 18, 2011 | 07:58 AM
lookitznite's Avatar
Well tell me if this is a good idea, I don't really track my car. My car is just for DD. I want to have a nice looking stance but not ruin the ride quality too much. I want the aggressive look, would it be bad idea to get the Swift Spec -R and run wider wheels? What are your opinions on that for a NON tracker?
Old Aug 18, 2011 | 09:14 AM
DriveHard_99's Avatar
I don't think you have to go crazy to get the look you want. I know with rims man you could simply do some basic calculations like a forward space measurement which would be from the rotor hat to the outer edge of the fender. Then you find the desired width you want to run and take this number away from the rim width and that provides you with backspacing. You can get really picky and then convert your backspacing into offset and make sure that the wheel you buy comes right out to your desired location and lower the car a moderate amount rather than going ultra aggressive and this would probably look pretty aggressive with the body lines.
Old Aug 19, 2011 | 01:19 AM
h4ckluserr's Avatar
Did anyone else's head just explode?
I always hated the offset math...
Old Aug 19, 2011 | 01:21 AM
h4ckluserr's Avatar
I was intending to support your point. Sincere apologies if it came across otherwise.
Old Aug 19, 2011 | 05:17 AM
Are any of you guys lowered by chance? I heard swift spec - r wasn't so bad, again, its just a DD and i don't plan to track my car or anything. Dont get me wrong the oem suspension is amazing but its sitting so high and i hate the body roll when i'm doing a sharp turn :[ plus I kinda want that nice stance...
Old Aug 19, 2011 | 06:41 AM
JDZNate's Avatar
Veteran: Air Force
I put on swift sport springs and whiteline rollcenter kit. Feels stock but just a little lower. Never scrape either.
Old Aug 19, 2011 | 06:43 AM
Kracka's Avatar
Eibach Prokits here with no complaints, they're great daily-driver springs.
Old Aug 19, 2011 | 07:42 PM
How much were the drop? Would you suggest Eibach or Swift spec -R?
Old Aug 19, 2011 | 08:15 PM
sfearl1's Avatar
Ive been debating on coils/springs a lot lately. I'm not going to track my car until I have it paid off, so I think the eibachs will satisfy my dd needs just fine.
Old Aug 19, 2011 | 09:06 PM
Seems like everyone is voting Eibachs...anyone know the size drop?
Old Aug 20, 2011 | 09:24 AM
SniperwolF's Avatar
plus 1 !
and for the other people who are worried about the geometry .. pick up some ROLL CENTER KIT from whiteline; that will help put the geometry of ur lowered car back to stock .. read about it then decide
