Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Slightly bent knuckle
Old Sep 21, 2011 | 10:51 AM
manofdafam's Avatar
I have a slightly bent knuckle, tierod, and strut. You have to look hard to see it but my wheel is slightly tilted in like a VIP car. Is this bad for my T-case?
Old Sep 21, 2011 | 11:39 AM
Kracka's Avatar
It's bad for your tires and unsafe to be driving on damaged suspension components.
Old Sep 21, 2011 | 11:43 AM
Vivid Racing's Avatar
a damaged suspension component has been stressed/fatigued. There's no telling what kid of strength is left in the metal. Your alignment is also out of whack now, causing weird handling problems I'd bet.
Vivid Racing can probably help you source new parts, either aftermarket or OEM. Shoot me a PM if we can help!
Old Sep 21, 2011 | 12:02 PM
black95tt's Avatar
Old Sep 21, 2011 | 12:13 PM
manofdafam's Avatar
thanks for the info guys, luckily the evo is not a daily so I will be going to a shop and asking what i needto fix it. Thank You
Old Sep 22, 2011 | 10:39 AM
Replace the stuff that's bent, and get an alignment. You should be able to see what's bent/broken with a visual inspection. It sounds like you've already done that anyway.
gui dube987
Apr 3, 2017 10:45 AM
ChrisO86
Jul 21, 2016 11:21 PM
Evoadam21
Apr 5, 2016 07:52 PM
adawang
Jan 25, 2016 06:44 AM
4G63 4EVR
13
Apr 24, 2009 10:53 PM
