Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
tire size help !!!!
Old Nov 3, 2011 | 05:29 PM
EVOXMR10's Avatar
tire size help !!!!
im planing on getting some ssr type f wheels 18x10.5 +25
what tire size should i get ?
im drop on tanabe springs df210
the tires i wanna get are the hankook ventus v12 evo k110
thanks
Old Nov 4, 2011 | 04:17 PM
EVOXMR10's Avatar
will 285/30ZR18 work with that size rim ?!
help is needed
Old Nov 4, 2011 | 05:13 PM
TheBlade's Avatar
a 285 is 11.2" wide, so I'm pretty sure any tire manufacture will OK that size fitting on a 10.5" wheel. I don't know about fitment with your drop, as my evo is OEM height, but I can tell you that tire size is +0.5" larger diameter than factory.
Most manufactures want you to keep your tire size within 5% of the diameter, which it is. I think in the threads I've read most people with a 10.5 go with 275s though, which is 10.8" wide.
Old Nov 4, 2011 | 11:02 PM
EVOXMR10's Avatar
yeah ima go with a 275/35 hope it wont rub in the rear.
Old Nov 5, 2011 | 05:00 PM
stEVOrgiX's Avatar
275/35 would be best. And they won't rub. Know someone with that exact setup and he's fine. Even has his lowered on Swift Spec R's
Old Nov 6, 2011 | 02:40 PM
EVOXMR10's Avatar
the swift spec r drop the rear 1" and the tanabe drop the rear 1.4" so i hope that .4 wont make it rub lol
Old Nov 6, 2011 | 04:43 PM
JBAutosports's Avatar
275s are your best bet for less rubbing situations but will probably still rub a bit.
285's look good though if you can get your rear rolled nicely.
Either way I would get your rears rolled. If you need help with tires let me know. Lots of good options out there.
Old Nov 7, 2011 | 10:50 AM
EVOXMR10's Avatar
thanks
TheChampiYon
Nov 10, 2015 05:48 PM
fatevo15
Jul 3, 2015 02:26 PM
Letsoner
Apr 5, 2011 09:37 PM
shinobee1
164
Dec 25, 2007 02:57 PM
Alchemist
Jan 9, 2005 10:56 PM
