Rear wheel stud
Rear wheel stud
Had a lug broken in half and got stuck on the wheel, I couldn't get it off with out ruining the wheel and of course the stud.
How do i replace the rear stud? does it just "bang out"? Or do i have to replace the whole Hub?
The stud will come out, but be easy with banging as it can damage the bearings.. mine tapped out rather easily, but I ended up having to take the hub off to get the arp studs in because they are so much longer than stock. Stock stud replacement should be fairly easy.
Gtizks
11
Jan 5, 2017 08:11 PM
vtluu
25
Mar 31, 2013 02:39 AM
change, evo, evolution, evolutionm, installation, mitsubishi, rear, remove, removing, replacement, replacing, stuck, stud, studs, wheel
