Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Is The Roll Center Correction Kit Necessary?
Old Oct 12, 2012 | 01:30 AM
bluedub1's Avatar
OP, you could try Front Suspension Pro from AUTOWARE to see how using the Whiteline RCK will affect your suspension. It's relatively cheap (~$100) and all of the inputs are floating around the Suspension technical forum somewhere.
If you do choose to use it, please do share your results.
Old Jun 27, 2013 | 04:42 PM
Startbutton99's Avatar
2013 gsr with swift spec Rs, stock shocks, and RCK. I was without the RCK at first.
There was definite improvement in handling from just the springs, after adding the RCK i noticed a better turn in on my turns. Increased responsiveness. I dont track my car, just a little spirited driving, and i'm planning on coilovers later so i wanted to get these things out of the way.
Is it worth it.. maybe not yet. the install takes quite a bit of work, compared to switching camber bolts.
In the long run is it worth it.. yes, especially if you plan on dumping your car on coils some day. For now.. i'm happy, im not going to take them off n sell them or anything. haha.
Old Jun 28, 2013 | 12:00 AM
BlewBuYou66's Avatar
Originally Posted by Crester
Honestly this car is just a fun daily driver for me. I do go to some track events... but not to compete... I run track days just for fun. So picking up a 10th of a second isn't the most important thing to me.
Right now I have the OEM Bilstein suspension and I am considering buying Swift Sport springs.
It cost roughly $300 in labor to get put in, plus you now need another alignment so that's another $90. I got the gtworx springs and its been more of a hassle then anything. But i do notice a slight advantage to having them over stock. I don't think it was worth it.
EGbeater
Aug 6, 2021 05:47 AM
mrwickd123
11
Jul 13, 2016 04:43 PM
DGlory
17
May 10, 2012 05:23 PM
19psi
14
Jul 6, 2011 07:44 AM
EGbeater
11
Jun 2, 2009 05:14 AM
