alignment numbers look ok?
Good morning everyone, I took my car in to get aligned yesterday after getting Eibach Prokit springs and Whiteline RCA kit installed over the weekend. I'm concerned about my rear camber, will this be ok?
FRONT (left, right)
Camber: -1.0, -1.3
Caster: 4.1, 4.0
Toe: -.03, .04
REAR (left, right)
Camber: -2.1, -1.9
Toe: .20, .10
Let me know what you guys think, if need be I'll take it somewhere else to get realigned.
Thanks
FRONT (left, right)
Camber: -1.0, -1.3
Caster: 4.1, 4.0
Toe: -.03, .04
REAR (left, right)
Camber: -2.1, -1.9
Toe: .20, .10
Thanks
it's reversed, you want -2.0 FRONT and -1.5 in the rear (at most for most DD'ers, go towards zero more if you're more conservative, farther away if not)
factory is -1.0 +/- 0.05; not sure on the deviation, but -1.0 is factory target
you want 0 toe all around unless you have an auto cross event you're preparing for that needs a toe adjustment.
I would agree with everyone that -1.0 degree on the front is not enough and you will see a nice gain in performance with -2.0 Front and -1.5 Rear. That seems to be the sweet spot for a daily driven Evo X.
Toe is what eats up the tires. In most situations, Camber has less of an effect in wearing the tires compared to bad Toe adjustment.
goofygrin
88
Jul 24, 2022 08:22 PM
TxFAkuma
Feb 17, 2017 03:45 PM
hispanicpanic
10
Mar 1, 2014 04:07 PM
runningonE
12
May 22, 2011 03:18 PM
EVO Rosso
Jun 25, 2003 06:06 PM
