Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Stretched tires and autocross
Old Feb 29, 2012 | 06:22 PM
EvoX-11's Avatar
I heard slight stretch gives extra performance. Is this true?
I am thinking about running 18x10.5 wrapped with 275/35 tire which will be slightly stretched. I know there quite a bit members here that autocrosses, please share your .02
Old Feb 29, 2012 | 07:09 PM
Iowa999's Avatar
A 275 on a 10.5" wheel is not stretched at all. Stretched is when the wheel is wider than the tire.
With that said, 275 street tires on 10.5" wheels puts you in a rough place: ASP or SM. Ouch.
Old Feb 29, 2012 | 07:25 PM
WarmMilk's Avatar
^what he said
to elaborate further, a little stretch is ok, but stupid stretch like a 225 on a 9.5 wide wheel will only slow you down
Old Feb 29, 2012 | 07:48 PM
EvoX-11's Avatar
I was going by this
According to that tool it is lil stretched.
Well I will be in street modified as soon as I leave novice class due to having an upgraded intercooler
So, whether I have 275s or not my future in autocross will be full of with loses
Old Feb 29, 2012 | 08:16 PM
WarmMilk's Avatar
275 on a 10.5 is fine
Old Mar 1, 2012 | 07:06 AM
Iowa999's Avatar
If I knew that I was going to be in SM in an Evo X, then I'd choose a wheel for 285/30/18s, in case I ever got the bug to be thuper therious. So I'd be looking at 18x11s, instead.
Plan ahead. Buy once.
Old Mar 1, 2012 | 07:23 AM
EvoX-11's Avatar
I was actually shopping for tires last nite and come to find out that 285/35s are only couple bucks more or a little cheaper than 275/35 depending on the brand and store.
So I was thinking about going with 285/35 as for my tires. Is there a reason why you said 285/30?
Old Mar 1, 2012 | 08:10 AM
Iowa999's Avatar
Here's the reasoning: With 285s, you'll have good grip. So, you want the torque to use all that grip. Ergo, for autocrossing, 285/30/18s, not 285/35/18s. Plus, shorter, so stiffer sidewall and lower CG. Also, every major tire maker offers a 285/30/18. Rather few make a 285/35/18.
Old Mar 1, 2012 | 08:40 AM
EvoX-11's Avatar
I thought having that extra side wall helps a lot with the turns. Hmmm.
I will be using these tires on the street too when I will be doing anything requires more grip. Like trip to dragons tail.
Maybe I should stick with my 19s since I am running 275/30s? I can always get better tires.
Old Mar 1, 2012 | 08:48 AM
EvoX-11's Avatar
I think that is the opposite man...
I am yet to find rs3, re11, starspecs or nt05s in size 285/30
Old Mar 1, 2012 | 09:40 AM
Iowa999's Avatar
Sorry. I was planning way ahead. I was assuming that you'll catch the bug in a serious way and will want Rs.
Old Mar 1, 2012 | 01:45 PM
4B11AWD's Avatar
Pretty sure you can run ASP (last season it was BSP) with an upgraded intercooler. SM (Street Modified) will be a higher class with upgraded turbos and more mods. Theoretically SM is a tougher class because of the allowances but realistically they are both extremely fast and competitive classes.
If you're running either classes you're S.O.L. if you're not running R-Compounds. Specifically 285/30/18 Hoosier A6's or Kumho V710's.
19's probably won't give you the right gearing ratios.
Old Mar 1, 2012 | 01:48 PM
4B11AWD's Avatar
A lot of the Asian manufacturers don't run past a 275 tire because the majority of the sales and street tire time attacks run a 265 or 275.
Old Mar 1, 2012 | 03:46 PM
EvoX-11's Avatar
I was referring to 285/30s. This size is only available for rcomps...
285/35s are not an issue to find at all.
Old Mar 1, 2012 | 03:53 PM
EvoX-11's Avatar
Trust me, I dont want to run in SM but they made it sound like I have no choice due to the mods I have on the car.
I will talk with the instructors before I move out of novice class to find the appropriate class that will suite me the best
