Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Need help with RP03's
Old Apr 2, 2012 | 02:43 PM
EVO LVED's Avatar
About to pull the trigger on Enkei RP03's in 19x10+22 with 275/35/19 Pilot super Sports. Need some advice on if this will work without rubbing or causing any issues. What do you guys think?
Old Apr 2, 2012 | 02:47 PM
eve-slow's Avatar
What is your suspension set-up? Camber specs?
Old Apr 2, 2012 | 07:15 PM
EVO LVED's Avatar
Sorry, should have said that everything is stock. I want to build the suspension to suit the setup. They salt the roads here in winter, is fender rolling more likely to promote rust?
I'm hoping the end result will be like this. This is not my first wheel choice, but I can get these with the tires for less than I would pay for Volks or Advans alone. And at 24lbs, the weight is pretty good for a $400 wheel.
Old Apr 3, 2012 | 08:41 AM
grillpt's Avatar
Ninja
Just realized I was in the X forum, sorry.
Old Apr 3, 2012 | 09:11 AM
Iowa999's Avatar
If you care about weight, then you probably care about performance. So why are you putting 19" wheels on your car? Are you swapping in a giant brake kit?
Old Apr 3, 2012 | 01:47 PM
EVO LVED's Avatar
Not at this point, but the car could certainly use it, the STI brakes way better than the EVO. This is a street setup, so I'm willing to trade a little bit of performance for a little bit more of a sicker look.
Old Apr 3, 2012 | 09:17 PM
jdm sam's Avatar
It depends on your drop and camber settings. The front will likely rub on full lock and the rear would need a roll.
Old Apr 4, 2012 | 12:54 AM
EVO LVED's Avatar
Well again, I'm stock right now. So will it clear stock? I guess what I really want to know is if this will clear with some reasonable negative camber, say -2 or less, and maybe a slight roll. Or will it take more than that?
Old Apr 4, 2012 | 12:31 PM
WarmMilk's Avatar
STi braking (stopping distance, car behavior under heavy braking) is better due to it being lighter and some weight distribution thing I can't pin point. The brakes themselves are better on the Evo. I've had an Evo and STi on the track the same day, Evo still had the original fluid, bone stock brakes and the STi had 3 day old fluid and stainless lines and the Evo had less brake fade and a firmer pedal as things got hot
Old Apr 4, 2012 | 01:01 PM
Iowa999's Avatar
We're actually 1% better balanced than an STi, but we weigh about 250# more. Maybe our CG is higher. That could be the balance thing that you can't pinpoint. Wouldn't surprise me. Boxer is nice and low.
edit: Nope. Bad guess on my part (that I should have looked up before suggesting). Lancer Evo: 509mm WRX STi: 534mm
Old Apr 4, 2012 | 06:55 PM
EVO LVED's Avatar
I think it also has something to do with the ABS. I find it just works better on the Subie. Panic braking on the street seems a lot shorter. Could also be tires. The RE070's on the STI are pretty damn sticky.
But please guys, back to the setup. =)
Old Apr 4, 2012 | 11:09 PM
jdm sam's Avatar
It will clear on stock just don't weigh the car down, wheel gap actually helps on that size tire/wheel. You really need to run 275/30/19 as the 35 will be too fat of a profile on the 19s.
Old Apr 5, 2012 | 07:45 AM
EVO LVED's Avatar
Thanks for the help Sam. Is there a big difference in ride quality from 35 to 30? When I lower the car it will be around 2 finger gap.
So a little negative camber abd a mild roll?
Brian Rees
Aug 5, 2015 02:57 PM
mister1161
Mar 12, 2014 01:59 PM
chmodlf
For Sale - Wheels / Tires
Aug 9, 2013 01:49 PM
Rp.cudd
Mar 17, 2010 07:42 AM
Ninosautoacc
Evo 'For Sale' Wheels / Tires
17
Jun 6, 2004 04:45 PM
