Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Front Camber Differences
Old Jul 3, 2012 | 06:56 AM
Crester's Avatar
I'm wondering how much difference in front wheel camber would make a difference to the car (ie... the difference between front-left and front-right values). Currently my front left wheel is at -1.8 degrees and my front right wheel is at -2.2 degrees. Is this something which I should look to correct? Or is it fine? The car feels fine when I'm driving it. I just don't know how much of a difference between the two wheels is required to think it's an issue.
The alignment shop told me the front wheels don't have camber adjustment... but they corrected all the other values. Now I've learned about the method of turning a bolt 180 degrees to add/remove a degree of camber. Some people further claim you can rotate this bolt slightly to try and match the front camber values.
Basically I'm just looking for feed back on whether I should leave the camber values as -1.8/-2.2 or try to match them evenly at -2.0.
Old Jul 3, 2012 | 07:07 AM
Smike's Avatar
+/- 0.3-0.4 is fine. Not something I'd worry about.
Alignment shop -- find a new one. They're wrong and should not be used again.
Yes, you can tweak the bolts some to get more even numbers. Up to you. I'd leave it be.
captobvious75
Jul 11, 2011 10:06 AM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
falcontx
Jan 31, 2008 10:29 AM
EVO8LTW
37
Sep 27, 2004 09:23 AM
iodine23
Apr 12, 2004 08:55 PM
