Why only 9.5 or 10.5 width on rims? Please help
Yeah if you're staying 245, there are really no benefits to going to a wheel 1.5" wider than stock other than looks. It's likely not to be lighter (unless you drop some serious dough). I'm at 265s on 9.5, stock suspension, so no rolling. Rubs only at full lock on the front fender liners.
Im thinking I might have to buy a roller and go for it. I have plenty of friends with beater cars that will let me practice on their car before doing my X.
On the other hand, I might have to drive on stock MR suspension for a month or two after I buy my wheels. How big of a problem is that?
I would get my suspension first but I'm waiting on a new version to get released and I have a bent wheel right now that needs replaced.
And by remote island I dont mean Im sipping pina coladas all day on the beach, this place is surrounded by lava rocks.
Ok, talked to a very wise dude at a very good tuning company and he helped decide on going with the 18x19.5 on a 275 wheel.
I mentioned the AMS and Gates Evo and he put it like this, "when you run with 900 hp you're gonna need the biggest wheel you can find."
I'm at half that and 9.5 sounds right all around. No need to fender roll and I run on stock suspension.
Anyone disagree?
Anyone disagree?
Anyone disagree?
Anyone disagree?
OP, if it were me, and it isn't but it soon will be, I would go with an 18x10 ET20 set of wheels with a set of 265/35/18 tires (a lot of options with this size, which is why I suggest it). If you rub, and that is a BIG if, the roll would be pretty minor. You need only find a body shop or performance shop locally with a roller and some experience. Also, that isn't much of a stretch with those tires, if any at all.
This is what that size looks like:
Those are 275 tires. That will require a roll for sure.
Ok well that's because your car isn't lowered very much if any.. That could also be because you're running a retarded sized tire and its stretched. Anyone I've seen and know to run 9.5 +22 and lower needs to at least roll the rears a little.
I run a 9.5" ET12 (245/40/18 tires), and I didn't need to roll the rear. That is within spec for tires of that size.
