Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Turning from straight to lock
Old Dec 22, 2012 | 12:17 AM
cdmassee's Avatar
So I noticed that my Evo (08 GSR) turns farther to the right then left.
maybe sharper is the better word.
Is this just mine? or is this normal and I'm an idiot??
Old Dec 22, 2012 | 07:14 AM
Iowa999's Avatar
Do you mean that the wheels steer farther one way than the other, or that you can rotate the steering wheel more one way than the other, or both? In any event, that's weird. The three 08s that I've driven all turned left better (and it's not because of my fat butt in the driver's seat since the owner of one was both bigger than me and riding in the passenger seat).
Old Dec 23, 2012 | 04:07 PM
cdmassee's Avatar
Both... the wheel turns farther from straight position to locked right...
and the wheels turn a bit sharper. Im not talking much but it does happen.
But as far as handling... it seems equal between left and right bends.
Old Dec 23, 2012 | 05:25 PM
Iowa999's Avatar
That's very weird. The only explanation that jumps to mind is that the steering wheel was removed and reinstalled in the wrong (clock) position. If this is true, then it needs to be fixed ASAP, because it will be giving importantly incorrect information to the ASC and AYC systems.
To be clear: all else being equal and correct, the steering wheel should be turnable an equal amount in the two directions. If this isn't true, it suggests that the steering wheel isn't at the right position which is not good.
ps. I'm aware that "turnable" is not a word, but, given how often I edit my posts to correct the grammar and spelling, I'm letting myself off on this one
Old Dec 23, 2012 | 07:57 PM
cdmassee's Avatar
I should probably figure out whats up with that then. \
The AYC has never done anything weird on me. It behaves like it is meant to... Or at least I'm assuming.
ehh... turnable makes sense, therefore its a word.
mdknutsen
Jul 12, 2016 05:51 AM
gooov
Jun 13, 2015 04:04 AM
MP Evo
Apr 19, 2015 05:11 AM
GundamPilot
Feb 19, 2010 03:14 PM
maplemaf
Oct 20, 2009 12:23 PM
