Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Ohlins DFV
Old Feb 5, 2013 | 07:17 PM
ASD_14's Avatar
Ohlins DFV
Hi Guys,
I have just purchased a set of Ohlins DFV coilovers off my mate who only had them on his car for 2,000km's. He took them off because the rear's were apparently noisy. He said it has to do with the rear camber plates (metal on metal).
Question is, how do i get rid of these noises?? can i put a thin layer of rubber between the camberplate and my chasis??
Thanks alot.
Old Feb 5, 2013 | 07:25 PM
Johnr352's Avatar
Noisy? When do they cause noise? Have you heard it? Can you inspect the camber plate and see where it is rubbing? You could try a thin sheet of plastic or Teflon (better than rubber) but it is hard to say without looking at the camber plates directly. We had some rubbing issues with our front KMac plates and ended up welding in a different spacer system, essentially redesigning the plates to work more effectively. You might take them to a shop and get their perspective.
Old Feb 5, 2013 | 07:30 PM
cfdfireman1's Avatar
Just one problem, pretty sure there are no "camber plates" in the rear (metal on metal) or not.
Old Feb 5, 2013 | 07:33 PM
ASD_14's Avatar
Thanks for that, i am picking up the coilovers off him in a week so i will look at them for any where marks or sign's on the rear struts or camber plates.
Old Feb 5, 2013 | 07:34 PM
ASD_14's Avatar
Not sure mate, i havent seen them yet as he still has them in his car. I will be picking them up in a week so i can look then. Although, i am pretty sure they do come stock with camber plates in the rear?? Could be wrong though. Thanks.
Old Feb 6, 2013 | 10:03 AM
Please post a picture of a rear camber plate on an evo. I'm curious to know how that will work with only 1 bolt on the bottom of the shock and no connection to the knuckle.
Old Feb 6, 2013 | 10:06 AM
davey111483's Avatar
yep never saw camber plates on the rears.
Old Feb 6, 2013 | 02:55 PM
ASD_14's Avatar
Yeah its not the camber plate its the top mount im talking about. Appologies.
So is there any way to fix this knocking / noisyness from the top mount then?? Thanks guys.
Old Feb 6, 2013 | 06:05 PM
Same Ohlins as I have on my IX and don't notice any knocking.
Old Feb 6, 2013 | 09:50 PM
ASD_14's Avatar
Ok no worries, well when i get them installed il make sure they loctite all the bolts and torque them correctly. Hopefully this will fix it, thanks.
Old Feb 6, 2013 | 10:29 PM
dave12285's Avatar
You'll want to make sure the spring perch along with the bottom locking ring are very snug. Use a screwdriver and hammer. You'll also want to make sure the spring isolator is in good shape. That's the rubber or plastic piece between the spring and the top shock mount. Good luck!
Old Feb 6, 2013 | 10:30 PM
ASD_14's Avatar
Thats the information i was after lol thanks buddy, il keep this in mind for sure
pshooter
Dec 1, 2016 03:36 PM
white_turbo
22
Oct 29, 2015 03:04 PM
JustinOlson
17
Jan 5, 2015 01:15 PM
DimitrisIX
15
Apr 18, 2008 03:41 AM
xwu22
Nov 13, 2006 11:27 AM
