The Works Wheels
Stock offset is +38mm. I'm not sure what offset they offer the Works Meister S1R.
Look here and you'll be able to find out the size that works best.
https://www.evolutionm.net/forums/ev...ent-chart.html
if you're stock height you won't have to unless you're taking some hard turns.
If lowered then you will have to unless it's like 30+ or more but I think it won't look as clean.
Buth then the other question to ask which offset clears the front brakes. You may need to a spacer to do that.
Another concern is different offsets may change the lip width or face shape.
Best to do is search for that rim on a X but I don't recall seeing anything in 9.5
Here's works site showing 10.5 which looks nice. http://www.workwheelsusa.com/news-post.php?article=87
It's not too hard to roll the fenders or you could just have it done. No biggie.
I was lowered on Spec R's on my X with 9.5 +22 (265 tire)with no issues. I believe if you go to +15 you would need to roll the rears if lowered.
I now have a set of 19X10 +20 with the same 5mm spacer (+15) Work S1R's, I have my rear fenders rolled but my car is much lower now.
If you have any questions about a good disc setup to order with the S1R's shoot me a PM, happy to let you know what my exact set-up was. Since these are two piece wheels, you can order the exact same size wheels but get a "staggered look" where the rear lips are larger than the fronts.
~Ryan
Evo8or9
May 14, 2013 02:35 PM
rmarte16
10
Jan 22, 2013 09:15 AM
BRUTA1
Oct 9, 2012 07:45 PM
nezro
Evo X How Tos / Installations
Sep 10, 2009 07:19 PM
