Suspensions for DD
I too recommend the Cobb springs, I put them on my car a week ago and so far I've been very happy. Good drop and solid ride quality. There was even a site I found awhile back seeking them for like 250. Can't remember where since I got mine off a guy here who sold his car before he ever put them on.
I see I see. Not sure about the tire size since I dont know much about them lol but rims will be 19x10.5 +22 or 19x9.5 +22. Not exactly sure what size Im going to get yet.
A RIM is "the upper or outer edge of an object." They are called WHEELS
Now wheels have a RIM ON THEM, but they are not called RIMS
Now back on topic
The down side with 19" tires is that its harder to find a tire the exact same over height as the stock side. You will ether be taller or shorter than stock.
With a 19x9.5 wheel you would want to run a 265 series wide and then a 30 or 35 side wall. 30 will be shorter height than the over stock size and have a smaller side wall. 35 would give you more side wall, but be taller than stock. I would personally rather have a bit more side wall so you are not driving on rubber bans for tires.
You could also run a 255/35/19 and that would actually be closer to the stock overall height to stock, but you will probably have a slight stretch of the side wall. The 265 will be more square.
With a 19x10.5 you will want to run a 285 series wide tire with a 30 side wall.
The 285/30/19 will actually be really close to the stock over all height to stock.
A 295/30/19 may also be an option as well. It will fit with a more square look than the 285 series wide tire on a 10.5" wide wheel and will be a bit taller than stock.
Stock 245/40/18 = 25.7" Tall
For 19x9.5" wide wheel
255/35/19 = 26" Tall
265/35/19 = 26.3" Tall
For 19x10.5" wide wheel
285/30/19 = 25.8" Tall
295/30/19 = 26" Tall
I would try to find a tire as close to stock height as possible and that is close to square on fitment. If you go to tall or to shot it can throw off your speedometer a bit. I have a car that I bought in the past that came with smaller than OEM tire height and my Speedo was off about 5mph. When I was doing 75mph I was really only going 70mph
I hope some of this helps though.
No problem
I am going 18's on mine to have more tire side wall since I drive about 60-70miles a day.
I don't want to be driving on almost no side wall and bend a wheel ether. More sidewall = a bit more protections
I also said that 18's would work well on both my Evo X and Evo 8 where 19's on a Evo 8 don't look to good in my opinion
I want to be able to swap back and forth on both of those cars
AWD cars must run tires whose diameter are the same (or very, very close) on all 4 corners, or you risk ruining your ACD. Since you have a staggered wheel setup, you will run into issues when trying to select tires with same diameter front/rear. I would recommend against trying to run bigger tires in the back with different diameters compared to the front tires.
No problem
