Suspensions for DD
I was planning on upgrading my stock suspension with a set of Muellerized Springs or Swift Sport Mach Springs and also adding a 15mm spacer when running the stock wheels. I have heard nothing but good things about Swift products.
Coilovers are a great choice if you dont plan on doing a lot of winter driving on the car. I have seen to many people drive on coilovers during the winter months, only to have the aluminum portion of the coilover corode to the point where you can no longer adjust the collets the adjust height and preload. If you are going to by driving this in the snow, I would go with a set of springs. Just my .02.
Plus some of the coilovers such as KW's are corrosion resistant
and are probably even better than the stock suspension offerings( they will either corrode just as fast or faster) if they are not properly maintained.http://kw-suspension.com/us/kw_inox_line.php
Are they overkill for a DD? Yes, but one could argue an Evo is overkill as a DD as well.
DK01
Nov 30, 2011 12:31 PM
DC2toEVO8
May 16, 2008 10:26 PM
