Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
rotor for DD
Old May 17, 2013 | 11:46 PM
Noe18's Avatar
rotor for DD
im searching to upgrade my rotor only, no racing not track. I heard about drilled cracking when tracking but are they good for DD, also i was searching for dimpled/slotted but couldnt find anything and are they good DD if yes point me in the right direction pls
Old May 18, 2013 | 12:09 AM
SaulHudson's Avatar
Centric blanks.
Old May 18, 2013 | 12:22 AM
Noe18's Avatar
Originally Posted by SaulHudson
Centric blanks.
you dont recommend anything that is dimpled or slotted?
Old May 18, 2013 | 12:33 AM
SaulHudson's Avatar
If you aren't tracking the car, no. Are the stock rotors already burnt out?
Old May 18, 2013 | 10:32 AM
lippy1306's Avatar
Centric blanks.
+1. If you aren't tracking your car you don't need slotted/drilled rotors.
Old May 18, 2013 | 10:47 AM
mitsubeastlee's Avatar
rotorpros from Map! great price you can go slotted dimpled coated etc. imo its not needed but the brembo pads do fade easily so i would change them (under hard braking street conditions)
Old May 18, 2013 | 11:41 AM
Noe18's Avatar
Not burnt out, I got new pads and ams ss line and motul fluid and was thinking to upgrade rotors, I have stock pads with 24400 miles
Old May 18, 2013 | 11:43 AM
bstgsr's Avatar
For daily driving, you dont NEED slotted/drilled rotors. It would be more of if you wanted the look on your car. Blanks would suit your needs just fine
Old May 19, 2013 | 10:02 AM
Noe18's Avatar
ok, thx ^^ ill stick with stock
mmp
19
Jan 4, 2016 07:55 AM
Roen
Feb 14, 2014 12:15 PM
EndlessRed
Jul 24, 2013 09:43 AM
Shtepic
10
Mar 31, 2013 02:06 AM
