Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Front control arm bushing question
Old May 28, 2013 | 06:31 AM
wtam1100's Avatar
I need to replace the bushing in my front control arm on my driver side due to a rattling noise. I can easily find a whiteline or works replacement for one of the bushing. But the bushing that the Perrin psrs replaces I can't find just a poly version. After some more investigation. The only company that I can find that is offering both bushings I am looking for is Prothane. It is listing the same kit (13-204) for all Lancer Evo from 03-13 can anyone confirm whether that sounds right?
Here is a link to the part
http://www.energysuspensionparts.com...asp?prod=13204
Here is a link to the parts catolog saying that it fits for Evo 03-13. See Page 53.
http://prothane.com/images/prothane_catalog_12.pdf
Any help would be much appreciated.
Old May 28, 2013 | 06:57 AM
Tuxevo's Avatar
I'm fairly certain the rear bushing diameter and height is the same in the 8/9/10 front lower control arms.
Old May 28, 2013 | 07:21 AM
wtam1100's Avatar
I'm really only concerned with the front bushings since that's what I need to replace. Looking at other parts more I'm really think it is correct. The Perrin PSRS is the same part number for EVO 8-10. And the whiteline bushing has the same part number (w0593) for evo 8-10 also. Just need a few others to chime in to see if they think this is correct also.
Old May 28, 2013 | 11:20 AM
chu's Avatar
chu
The PERRIN PSRS is the only recommended upgrade. Energy Suspension makes that bushing for the Evo 8 & 9, but there has been a lot of consensus that the stock version is much better than a polyurethane due the OEM being spherical inside. Robispec also mentioned this in an older MotoIQ article.
Old May 28, 2013 | 12:31 PM
wtam1100's Avatar
That is good to know but I honestly wasn't trying to upgrade but I might anyways since if I go that route I know everything will fit and I'm honestly tired of researching and wondering.
Old May 28, 2013 | 12:40 PM
chu's Avatar
chu
You should know that the PSRS is a full aluminum piece, and can transfer vibration. Just something to think about if the cars is a daily driver.
Old May 28, 2013 | 12:51 PM
NOSintake's Avatar
I'm looking into control arm bushings as well. Any reason why you didn't want the Whiteline or Works ones?
Old May 28, 2013 | 01:09 PM
wtam1100's Avatar
Yeah. From the reviews I have read it not really a noticeable difference so hopefully it'll be alright.
marco4089
Oct 7, 2015 07:20 PM
jvw
Jul 15, 2015 05:54 PM
turbotsi
12
Oct 28, 2011 01:08 PM
polish_pounder
14
Aug 20, 2011 12:43 PM
jwick76
27
Jun 2, 2008 05:30 PM
