Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Whiteline Rear Endlink Issues
Old Jul 13, 2013, 12:23 PM
WRC-LVR's Avatar
You can always make your own using male female Aurora heim joint ends, rolled thread stud material, metric bolts and taper spacers along with nylock nuts.
Old Jul 14, 2013, 09:53 PM
WarmMilk's Avatar
^Yeah, but then dirt gets in them and they wear out fast... The whole point of the WL end links is that they're sealed, so they don't wear out fast
Old Jul 15, 2013, 01:54 PM
jdizzle37's Avatar
That's certainly true warmmilk. Incidentally, it seems that most of the end link options out there for the Evo X are of the spherical bearing type. Racing Line seems to be the only one that has polyurethane bushings to act as a dust boot and reduce NVH.
To date, most of the feedback I've found between all of the rear end links point to this one being one of the finer choices. I will most likely be trying these next. I would much rather clean a spherical bearing once a year than retighten end links every 100 miles.
Old Jul 15, 2013, 05:18 PM
WarmMilk's Avatar
how about I ask this question, how many people on here are running Whiteline endlinks with no issue?
Old Jul 16, 2013, 06:54 PM
WRC-LVR's Avatar
You can also buy the rubber boots to go over them, fill them with grease and then no dirt will get it :-)
Here is a link to making custom Evo 8 rod end endlinks.....Evo X will be similar but you will have to measure overall length and get the correct adj center rod lengths
http://www.cs.unm.edu/~donour/cars/evo_endlinks/
You can google the rod end boots easily FK Bearings makes them
Old Jul 16, 2013, 10:31 PM
WarmMilk's Avatar
I already have the whiteline endlinks, so ill try those first, if they give me issues I'll start looking for another solution
Old Jul 16, 2013, 10:44 PM
BEKevo's Avatar
Definitely liking those homemade end links ! Great job on those
Old Jul 17, 2013, 06:05 PM
WarmMilk's Avatar
do you have a link for the rod ends boots? the only ones I've seen look pretty useless...
Old Jul 28, 2013, 07:13 PM
wenbenten's Avatar
Installed my front and rears bout a month ago. 100 miles later all seems well.
Old Jul 28, 2013, 07:15 PM
wenbenten's Avatar
wl endlinks on front and rear. no noise at all
Old Jul 28, 2013, 08:26 PM
denlin68's Avatar
so mine comes loose 3 times , everytime happens after i went to track days too ...... so when i used the 17mm wrench to hand tight i make sure i use a extended wrench (make ur own leverage) so i can crank it real tight and then i always double nut :P
Old Jul 29, 2013, 05:41 PM
whiteline jim's Avatar
Hi All,
We have seen this thread and we always like feedback either positive or negative to always improve our products.
We are now looking at these as it seems this is only the case on certain models of cars that this ever happens. We will trial different style washers and ways to keep then secure and will make changes as soon as we find a solution.
These joints are not failing or any part of the link so we just need to improve why they come loose on some cars and at this stage feel a few suggestions in this thread might be the way to go so thanks for the feedback.
If you do have any issues with links you have purchased we are great with our after sales/ customer service so do not hesitate to email us at support@whiteline.com.au and we will endeavor to solve any issue present.
Thanks !
Old Jul 29, 2013, 11:16 PM
ryancb's Avatar
I am also having this on a 2012 MR. tightened fully one morning. did 4laps on auto-x 60 sec course. within 100 miles driving home it was loose and sounding horrible again.
Old Jul 30, 2013, 03:08 PM
Hi Ryan,
please email us to discuss the issue and we will work out a solution for you .
Old Jul 30, 2013, 04:19 PM
ryancb's Avatar
I did yesterday Jim, no reply yet.
Quick Reply: Whiteline Rear Endlink Issues
