centric premium rotor
Yes, Fedja, the dimensions are identical (because the calipers and brackets are the same across all sub-models of Evo X). You can put two-piece rotors on a GSR and/or one-piece rotors on an MR.
That, folks, sums up SCCA autocrossing perfectly. People would protest a car that had parts that were worse than OE in every way, simply to move up a spot.
Lucky for me, I was always close enough to dead last to never have to deal with it.
when you guys change the rotors, do you guys change all 4 or just the fronts. i know the most stopping power are from the fronts.
if its not worth it to change the rear rotor, i will just replace the all 4 pads and the front rotors only.
You make a call depending on conditions of your rotors (front or rear). If they need replacement, you replace them! If you can just turn them, you do that too. For mostly DD you can get away with slightly worn ones for a while too, but if you are chasing tents and milliseconds, every bit helps everywhere!
As of most of the braking is done in the front stays, but EVO X wouldn't have huge rear breaks for no reason!
Fedja
Fedja
I worked at a parts store with Centric Brakes.(sold the product for 2 years) I strongly recomend them. I would use their Economy rotor before turning my OE rotors if in $ pinch. The reason is less metal equals less heat transfer. Hotter brakes more likly to get a pulse. Now Pads I could talk about also.
Also - hotter rotors are more likely to generate brake judder from overheated pads.
Also note - less mass is one of the easiest ways for cheaper rotors to be made. Less iron, lighter to ship etc all adds up the pennies.
-Ken
FS[Northeast]: OEM 2014 Front & Rear Rotors - 300 Miles
steve0677
Feb 20, 2015 10:32 AM
