Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Rubbing cant find where...
Old Apr 23, 2014 | 09:19 AM
jmichetti's Avatar
My set up is.. RPF1 18x10.5 275/35. Camber is -3 front and -2.5 rear... Lowered on BC Coilovers. I cut out the top middle section of the fender liners still unable to go any lower guessing the tires are too wide. Any ideas that might help?
Old Apr 23, 2014 | 03:19 PM
keshav707's Avatar
Rear fender bolt that holds the bumper.
Old Apr 24, 2014 | 04:16 AM
Johnr352's Avatar
I presume you are rolled too?
Old Apr 24, 2014 | 09:50 PM
Dpiedra92's Avatar
Your tires are too wide! I have the same setup and same coils.. But my tires are 265s. I went full camber on the bc coils.. And -3 in the back.. No rub at all.. Only in the front if the road is realllly uneven but very minimum
Old Apr 25, 2014 | 05:46 AM
DABAZZ's Avatar
yeah, those are some wide wheels man lol!
Old Apr 26, 2014 | 05:34 AM
Treyzian's Avatar
Wheel size and tire size are fine. Many people even run wider.
You'll need a roll and a pull in the rear, front's will need the fender liners heat gun'd and pushed, and maybe a slight roll depending on how much camber (or the lack of) there is.
Old Apr 26, 2014 | 11:15 AM
jmichetti's Avatar
Im thinking the tires are too wide to go low tho... Ill get some 265's next time around
Old Apr 26, 2014 | 03:36 PM
Johnr352's Avatar
We run 295 30, frankly, they fit better than the 275 35s. Now, to be fair, we are rolled, sans liners, cut, pulled, shaved, sanded, lubed, pushed, and yanked, but no rub.
Old Apr 26, 2014 | 04:41 PM
Roen's Avatar
What offset?
jacked cobra
May 3, 2015 09:29 PM
splizaat
Mar 7, 2015 06:00 PM
Wapoosh
Mar 4, 2015 11:01 AM
Dannyboy22
Jan 18, 2015 01:59 PM
jmichetti
Apr 23, 2014 11:56 AM
