Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
HSD coilovers
Old May 17, 2014 | 07:31 PM
Mikeodeth's Avatar
HSD coilovers
Hi
I just installed hsd coilovers and there is a ding sound everytime i turn. I can also turn the coil spring with my bare hand.
Pls help
Old May 17, 2014 | 07:49 PM
blusubman's Avatar
does it sound like its coming from one side or both sides sound like they are binding up?
Old May 17, 2014 | 08:12 PM
Mikeodeth's Avatar
Mostly one side but both
Old May 17, 2014 | 08:14 PM
Mikeodeth's Avatar
Are the spring supposed to be tight or it can be twisted easily?
Old May 18, 2014 | 05:20 AM
ghozt's Avatar
I'm not positive, but it sounds like your preload is not set correctly. At least on the one making the noise. And you should not be able to turn the spring by hand.
Old May 18, 2014 | 08:08 AM
Iowa999's Avatar
Pre-loading a front spring on a car that is only driven on tarmac is highly over-rated. Just focus on having the total travel balanced between bump and rebound. As to the click, I would start by looking at the top-mount. Even some of the aftermarket versions aren't so great (and the OE tops are pieces of junk). With that said, I agree that it's more likely to be the spring, which might need a Torrington bearing.
supersupra
May 4, 2016 11:21 AM
Mikeodeth
Mar 22, 2015 07:34 PM
LAY6C
Toronto Lancer Club
Apr 2, 2012 08:18 AM
lil.riceboi
Sep 1, 2010 04:09 PM
EVO LVED
Mar 12, 2010 10:43 AM
