Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Will I need spacers?
Old Jun 3, 2014 | 05:57 PM
Fat_Jerry's Avatar
Okay so i just bought these: 18" Enkei Rims NT03+M 18x9.5 5x114.3 +27 Black 03 04 05 06 07 08 09 10 EVO 8 9 X for my evo x. I am not sure if I will need spacers, I tried to use the chart, but I was having some difficulties, so if someone could just help me by telling me if I will need spacers. Thanks
Old Jun 3, 2014 | 06:15 PM
Nagua's Avatar
Don't use spacers. Get the rims with the correct offset.
Old Jun 4, 2014 | 07:58 AM
Iowa999's Avatar
The thread-starter's question can't be answered unless and until he or she tells us what tires will be used. The wheels, themselves, won't hit the suspension, so it's quite possible this will work.
Alternatively, since the thread-starter said that he or she has already bought the wheels - did you miss that part, Nagua? - he or she can wait until they arrive and test them on the car. It's the front that matters, given that this is a relative high offset.
Old Jun 4, 2014 | 08:18 AM
Santorican's Avatar
I'd check out this thread as it probably has the information you're looking for.
https://www.evolutionm.net/forums/ev...s-go-here.html
Old Jun 4, 2014 | 04:41 PM
evo9cuhh's Avatar
You will need to run an 8mm custom spacer to fit perfected or 10mm spacer with studs unless you're planning on get a slip on and running extended studs.
Old Jun 4, 2014 | 05:21 PM
Iowa999's Avatar
How you know this without knowing what the tires will be is beyond me.
xMCxMRx
10
Jul 31, 2015 06:47 PM
elkazX
Jan 15, 2015 02:24 PM
Dannyboy22
10
Oct 9, 2014 09:08 AM
Psybin
Feb 11, 2014 02:32 PM
ron2003
Dec 22, 2013 09:41 PM
