Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
2014 Winter Tire Reminder
Old Oct 7, 2014 | 12:04 PM
Neal@tirerack's Avatar
It's that time for my yearly winter tire reminder. We have had flurries here Indiana already and a handful of places in the U.S. have experienced measureable snowfall.
Popular tires for moderate to low snow climates, that see more plowed roads than highways, tend to be the Bridgestone Blizzak LM60, their new LM-32, and Dunlops Winter Sport 4D. Both are considered very equal to each other in snow traction and in dry road handling/cornering and were the tires of choice in this category. The Bridgestone's move the balance closer to the snow traction side while the Dunlop does slightly better in dry. Both an ideal choice for someone having trouble deciding between the high performance snow tires that sacrifice a lot of snow traction and the Q/R rated snow tires that trade off too much in handling and dry grip.
Persons living in more rural areas or heavy snow climates lean toward the Bridgestone Blizzak WS lines or Michelin X-Ice Xi3. I've noticed when driving both that the added tread depth of the Blizzak helps deep snow traction on those early unplowed mornings. The X-Ice is a bit happier on ice surfaces and tends to handle a bit tighter on clear roads due to the 2/32nd's difference in depth compared to the Blizzak.The WS80, Bridgestone's newest member to the Blizzak family, will be replacing the popular WS70 this year. From our ice rink testing I can tell you it's already better than the original WS70 and out cornered/accelerated the Yokohamas, Michelin, and Goodyear. Steering response is more crisp also.
Some more cost effective players to the game such as Yokohama's iceGUARD iG52c did well against tires like the General Altimax Artic. However, it is fairly new so jury is still out on long term results.
I would not wait too long, it's better to be proactive than reactive. Ordering early when most products are still available lets you choose what you want to buy rather than being forced to settle for what is left over. Best to be ready with products in hand before it snows so that you can put them on when you are ready, rather than waiting for a shipment to arrive after the first snow. We should have most inventory available now to mid November. Tires and wheels purchased together are mounted and balanced at no charge to make changeover easy and we do offer the oem pressure sensors.
You can view full winter tire and wheel packages at our winter upgrade garage.
Remember to mention "Neal ext 4624" in the comments section of your online order. This way I can review the order and process it faster. As always you may call me direct also
Old Oct 11, 2014 | 04:08 PM
deanmeon's Avatar
Just placed my order! And mentioned your name in the comments.
Old Oct 11, 2014 | 06:15 PM
.M.'s Avatar
.M.
I was just thinking about this (tires). Time to go shopping.
Old Oct 11, 2014 | 11:34 PM
MR. EVO MR's Avatar
Is the LM32 an upgrade of LM60?
Old Oct 13, 2014 | 01:26 PM
Great! PM me your order number, haven't seen one come through yet.
Correct, the 32's replaced 60's. A bit better wear and handling compared to the previous generation.
Old Oct 13, 2014 | 01:35 PM
shekaar's Avatar
I'll be putting my WS70's on soon enough! Love plowing through snow with real snow tires
Old Oct 13, 2014 | 01:43 PM
grazzo77's Avatar
It's 90° today in NorCal! :P
Old Nov 20, 2014 | 04:27 PM
FSD's Avatar
FSD
Thanks Neal,
Ordered my 235/40R-18 Bridgestone Blizzak WS80 XL today for my stock rims- 2010 Exo X SE
Went with the 235's over the 245's as my street maybe get plowed 24 hours after a snow event, 48 hours if its 6" plus.
As a side note on Tire Rack my shop called around to its 2 suppliers and the cheapest I could get them was $222 each before mounting and balanced and more than a week before they could be delivered at my Auto Shop.
Tire Rack with the 2 year protection thrown in (I live in PA which is pot hole central) and paying for shipping came to $203 each and will be here in less than 4 days.
So buying from Tire Rack saved $$$ and with the savings mounted & balanced equates to the cost of just the tires ordering from my Auto Shop.
Oh, did I say it thanks Neal and evolutionm
Old Nov 20, 2014 | 04:52 PM
Thanks for the order! Yup, you'll really like those especially in the narrower size. Money saved = more lol
Old Nov 20, 2014 | 06:21 PM
stiggysaurus's Avatar
just swapped to my winters today!
Old Nov 24, 2014 | 04:38 PM
Ancyker's Avatar
I've had these just over a week now:
Not a ton of snow yet. We did get a dusting, enough to cover the roads on a mountain that I go over on the way to work. It varies between a 9-12% grade. There was an accident on it, a pickup with a trailer ran off the road coming down (understeer). He was ok, his truck was not. Anyway, because of the accident I had to stop, in the snow, on the uphill side, at night, around 20F. Car got started again without any issues. No traction control lights, no spinning, no noises... just like it was dry. The SUV in front of me spun a lot and barely got started. Fairly impressed so far.
Dry handling seems comparable to an all season tire, probably a little better but it's hard to say since I've never had all seasons on the evo. It's better than other cars I've driven in the winter on dry roads, so it works! I do miss the advans... but I also miss summer! Cold with no snow is boring.
Ride comfort seems fair, no worse than the OEM tires, maybe even a little better.
Old Dec 11, 2014 | 03:17 PM
NEpsiOver21's Avatar
Hey Ancyker, what PSI do you those blizzaks to? I'm wondering if a winter tire should be set to the same pressure as the summer (which is the manufacturer recommended 32PSI).
If anyone else wants to chime in, feel free.
Old Dec 13, 2014 | 12:56 AM
Imprezme's Avatar
General tires make a set of awesome snow tires!
Old Dec 14, 2014 | 06:27 PM
Ancyker's Avatar
Same as stock. When I got them I asked the guy if I should do anything different and he said no, so I didn't.
Been around 2000 miles now, so far I've driven in light snow (just barely covering the roads) 2 or 3 times, no real snow fall to speak of sadly. Also played around in a parking lot early in the morning. Didn't feel like the car even noticed the snow was there. Same goes for colder rain/wet roads. It's a little strange doing 55MPH and feeling completely in control like it's almost dry while you pass others going as slow as 20MPH or less.
It's easy to forget the roads are "bad" with these, which I'm not sure if that's a good or bad thing. I parked in a parking lot and got out of the car and nearly slipped, didn't even know I parked on ice until I got out of the car.
Side note: WS80 no longer appears on the tirerack site for the evo... not sure why...
Old Dec 16, 2014 | 01:12 PM
Sold out for the season so they pulled them from our site.
