Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
ATEQ Mitsureset TMPS Tool
Old Dec 28, 2014 | 09:18 PM
bluedub1's Avatar
Has anyone tried the ATEQ tool?
The other thread mentioning ATEQ was from 2012, which did not work with the Outlander/Lancer.
http://www.ateqtpm.com/mitsureset/
Amazon.com: ATEQ Mitsubishi Lancer Outlander Mirage Tire Pressure Monitoring System TPMS Reset Tool: Automotive Amazon.com: ATEQ Mitsubishi Lancer Outlander Mirage Tire Pressure Monitoring System TPMS Reset Tool: Automotive
Old Jan 4, 2015 | 10:08 AM
Chance575's Avatar
Just bought it for a winter setup, I'll post a review in a few days once I get everything. Reviews I found said works with no problem.
Old Jan 7, 2015 | 09:20 AM
hoobastnk90's Avatar
OOOO i hope it works i will be buying one!
Old Jan 8, 2015 | 01:59 AM
Chance575's Avatar
Soooo my winter wheels went on and no tpms light yet. No reprogramming or anything. If it stays off gonna return everything
Old Jan 8, 2015 | 07:49 AM
bluedub1's Avatar
By any chance do you know if the tool can be used on more than 4 vehicles? I think the other versions of ATEQ limited use to 4 vehicles.
Would you be willing to sell it?
Old Jan 8, 2015 | 05:59 PM
Firebuck2059's Avatar
So is everything you need included? It mentions a triggering device as well so I am a bit confused.
Old Jan 10, 2015 | 04:08 AM
Chance575's Avatar
If you read my post you will see I didn't use it so unless you want to give me full price for it I'll return it for a full refund.
You will need the mistu reset tool and a trigger tool. Total cost was right at $280 total
Old Jan 12, 2015 | 11:01 AM
Chance575's Avatar
Light finally came on after about 40 miles of driving. Use tool and it works just fine.
You will need the Mitsu Reset tool and a Trigger (I have the cheapest a VT15)
Old Jan 12, 2015 | 01:08 PM
Robevo RS's Avatar
let me know how it will work out for you. So far the other tool didnt worked for me.
So i am still looking for options.
Old Jan 12, 2015 | 03:51 PM
RazorLab's Avatar
So this tool is for synching sensors then. You need to have sensors in the wheels. It won't turn off the actual check, correct?
Old Jan 12, 2015 | 05:59 PM
Chance575's Avatar
must have sensors in wheels, just reprograms to accept the new sensors
Old Jan 13, 2015 | 03:05 PM
bluedub1's Avatar
Are you sure it doesn't disable the TPMS system as well?
I read on the other forum that the tool (previous version) allows reprogramming and disabling of the TMPS sensors/system.
Appreciate the feedback, Chance575
Old Jan 13, 2015 | 03:10 PM
bluedub1's Avatar
Also, is it true that each device can be paired with only 4 vehicles?
Old Jan 20, 2015 | 02:17 PM
TPMS N.G.S.'s Avatar
You still have to have 4 tpms sensors on the car, I can source you a set of 4 alligator sensit sensors and valves for under $250 free shipping, these would be programmed to clone your OEM wheels.
I think this works for folks that have bought a set of used wheels with some sensors in them or for folks that have gotten rid of their OEM TPMS and do not have the codes.
Old Apr 20, 2015 | 08:24 PM
lanxe's Avatar
Mitsureset on eclippse
mitsureset is working on mitsubishi lancer, rvr and outlander is correct.
needs to do factory reset after each vehicle using webVT
seems the unit has some memory of the sensors
tried with eclippse, it didn't work, eclippse needs standard odbII
i am thinking that if i program the mitsureset with my rvr using the eclippse's tpms sensors and after programming, then connect the mitsureset to the eclippse, it will work, can anybody try this idea? if this is so, mitsureset and VT30 will do standard odbII
