Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Car Pulling To The Right
Old Nov 28, 2015 | 04:52 PM
asianhommy's Avatar
Just did some spirited driving this morning and as I was exiting the motorway there is a curved off ramp, I'd say about a 40 degree left turn. Decided to try out my new set up (Swift spec r on MR bilstein shocks and 18x10.5 +15 Works, 275/35 tyres) at 120 kph (~75mph) and the car was pulling to the right at two points during the turn. Is this normal? I've been paranoid about the reduced handling ever since I decided to go a bit wider with the wheels.
Old Nov 29, 2015 | 04:22 AM
Chef-j's Avatar
Have you check your tires? I had same issue on evo 9 because uneven tires.
Old Nov 29, 2015 | 07:56 AM
e_kobz's Avatar
What's your alignment specs? Have you had an alignment after installing your new suspension setup?
Old Nov 29, 2015 | 09:09 AM
Ryno9999's Avatar
^^^ Agreed just a touch of toe out will make it pull to that side especially under braking.
Old Nov 29, 2015 | 10:49 AM
asianhommy's Avatar
All tyres are brand new and only have ~200km on them so I'm assuming they're even. Yes, I've had an alignment, will post up the complete alignment spec sheet when I get home.
Old Nov 30, 2015 | 12:37 AM
asianhommy's Avatar
Old Dec 2, 2015 | 06:37 AM
Ryno9999's Avatar
Was it pulling before the new tires and alignment?
Old Dec 2, 2015 | 10:47 AM
asianhommy's Avatar
No, it wasn't. I've taken the same turn at similar speeds before but I was running 18x9.5 +20 w/ 265/35 back then.
suby2evo
38
May 23, 2011 12:30 PM
Audi2Evo
10
Jun 6, 2009 03:22 PM
Ride_59
11
Apr 24, 2006 03:47 AM
bluedd
Jan 31, 2005 01:53 PM
evolucionado
Apr 11, 2003 04:41 PM
