Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
The ultimate solution for understeer?
Old Apr 8, 2016 | 05:41 AM
hispanicpanic's Avatar
Originally Posted by alleggerita
The calculated data you describe absolutely coincide with what my seat of the pants feel suggests ....
So you are suggesting that the PSRS (offset?) in addition to limiting toe change as a result of the solid bushing also has a geometric effect on limiting toe change/bumpsteer as the suspension moves through its arc?
So how does the additional caster/moving the suspension arm do that? Would you care to explain?
Thanks
If anything a psrs will prevent toe out under suspension loading, which may or may not counteract all that toe in. Additionally, a stock or poly front LCA bushing will exacerbate the toe in condition. Leading to a net toe in condition by preventing a stock rear lca bushing from squishing inwards to counteract some of this toe in.
The only other effect of the PSRS is that by pushing the wheel forward, you're moving the tie rod pickup point forward as well. Since the rack cannot move forward by the same amount, you are essentially (and ever so slightly) changing the toe in condition by forcing the tie rod to travel in a tighter arc. In a case of rear steer, it could force toe out as the arc shortens faster.
This is all assuming there is zero caster. Since we have plenty of positive caster (7.5 with psrs + vorslag plates) The hub will move rearwards during compression, essentially straightening out the arc of the tie rod. And in a rear steer hub (that's what we have), it will actually force a toe in condition. I don't know what the relationship is between the two, but i think there is honestly a NET tradeoff for the worse by adding caster (in regards to toe). Atleast that's what my hunch is telling me without measuring it.
The only way to tell for sure is to measure it. Good thing i have fully adjustable LCA's that i can measure this on in the coming weeks
Old Apr 8, 2016 | 06:38 AM
Edited the post with the graphs to provide more info.
Also added two graphs with stock camber/steering axis inclination for refference.
Old Apr 15, 2016 | 05:31 AM
picture of the setup i used to measure for those asking me questions. I think its pretty self explanitory
Old Apr 15, 2016 | 07:09 AM
Robevo RS's Avatar
welded rear evo IX diff. lol
that is ultimate
Old Apr 15, 2016 | 10:38 AM
LetsGetThisDone's Avatar
that is ultimate
For a rally car maybe
Old Apr 15, 2016 | 01:20 PM
Robevo RS's Avatar
not even lol
Old Apr 16, 2016 | 01:58 PM
migs647's Avatar
Moving to suspension section. Also subscribed to learn more
Old Apr 19, 2016 | 05:38 AM
Here's some parts **** for you guys.
Taking measurements tonight.
Old Apr 19, 2016 | 01:23 PM
RJones's Avatar
Originally Posted by hispanicpanic
Here's some parts **** for you guys. Taking measurements tonight.
Race Fab?
Old Apr 19, 2016 | 01:35 PM
Originally Posted by RJones
Race Fab?
Nope. Hispanic Fab.
These are longer than the racefab units.
Old Apr 19, 2016 | 01:45 PM
RazorLab's Avatar
Interested in where this goes. I had some interesting moments at my last track event (minus blowing up my engine) where the car felt great overall but some random moments where understeer came out of nowhere.
It was easily driven out by lifting a little to get the back end to rotate, little bit of counter steer and then throttle on, but that was slowing me down.
Old Apr 20, 2016 | 05:39 AM
Well, the first prototypes didn't fit up like i wanted them to. I took measurements from a whiteline balljoint, and now it seems i should have just taken measurements from the upright in the first place :/
Hopefully i can get another set made within a week and take more measurements.
On a related note, anyone with an 8/9 that is converting to X arms, let me know. I have a tie rod adapter/sleeve that you'll need to finish a swap like that.
Old Apr 29, 2016 | 06:16 PM
Young king 2289's Avatar
Seems like good info in here,I'm gonna sub so my noob *** can learn something.
Old Oct 30, 2016 | 11:02 AM
patmaxx's Avatar
Very nice info there , but I don't understand how, with this setup, you account for track width variations ?
See how a Longacre bump steer kit is made, it follows the front of the plate fixed at the hub, thus measuring only toe variations.
Old Oct 31, 2016 | 08:49 AM
It doesn't matter what the track width is really. You establish a baseline at full droop, and meassure the change as you enter full compression. Then when you graph the toe chanve vs compression, you just choose the middle of the compression as your zero.
