Quote:
I'm currently running a 10.5+30 265/35 NT05s and am using a 15mm spacer to clear my coilovers by a credit card width. Brake clearance won't be your problem - suspension will.
*edit*
read up and looks like you're on coils.
You should be able to run a 285/35 if you really wanted to.
-asher
without spacers? What size bolt would I need with the spacers?Originally Posted by static_set
You're gonna need a lot more than 10mm of spacing if you're not running coilovers.I'm currently running a 10.5+30 265/35 NT05s and am using a 15mm spacer to clear my coilovers by a credit card width. Brake clearance won't be your problem - suspension will.
*edit*
-asher
Quote:
this isn't a VW or BMW my friend - our cars do not use bolts. They use studs. Originally Posted by wizechef
Based on my experience you will need at least a 15mm spacer to clear a 285/35 on a 18x10.5+30. You can get the bolt on type, or do it the right [i.e. safe] way and use extended studs.
Seems as though some people in this thread have different experiences though, so you'll just have to work it out.
-ash
-ash
I meant studs. Lol my bad. I got new studs when I had 10mm on the evo 8. The studs and spacers came with the wheels thou so I wasn't sure what size to get. Originally Posted by static_set
this isn't a VW or BMW my friend - our cars do not use bolts. They use studs.Based on my experience you will need at least a 15mm spacer to clear a 285/35 on a 18x10.5+30. You can get the bolt on type, or do it the right [i.e. safe] way and use extended studs.
-ash
I didnt get 285s I got 275s on a 18x10+30. Some said I might not even need a spacer.
Thats my main question. Do I need a spacer? If so, do I need studs and what size.
Quote:
-ash
Based on my experience you will need at least a 15mm spacer to clear a 285/35 on a 18x10.5+30. You can get the bolt on type, or do it the right [i.e. safe] way and use extended studs. -ash
This is my main answer.
Quote:
Thank you for your input. but I am going with a less wider rim and tire.Originally Posted by static_set
