Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Suspension knock
Old Jan 11, 2021 | 02:08 PM
nglett's Avatar
Suspension knock
After installing a Whiteline sway bar kit, I now have a knocking noise coming from the rear suspension. Has anyone else had this same problem? I’ve recheck all my bolts and everything is torqued to factory specs.
this is the kit I’ve installed
https://www.maperformance.com/produc...hoCjl8QAvD_BwE
Old Jan 11, 2021 | 05:55 PM
Jaraxle's Avatar
Yes I fought with that hardware for a bit, and couldn't get it to stop rattling. I wrote to whiteline and they asked for pictures. After sending them what they wanted, they sent me an updated kit. I do not know if you have the updated kit or not, so you would have to figure that out. Once the updated kit was installed (the ends links I am speaking of), and I added an extra nut to act as a jam nut, then all problems went away.
Old Jan 11, 2021 | 06:02 PM
nglett's Avatar
Thanks for the info, I’ll call them to see if I need an update kit. When did you purchase your sway bar kit?
Old Jan 12, 2021 | 05:06 PM
Jaraxle's Avatar
Years ago, but sometimes stock can sit on the shelves. Def check with them, they seem to have good support.
YoManStation
11
Jan 27, 2014 08:01 PM
catman78
12
Mar 27, 2012 05:15 PM
WWIXMR
15
Sep 14, 2010 10:07 AM
CrZZyLancer
11
Jan 10, 2007 08:06 AM
RBMotoring
Sep 22, 2003 02:34 PM
