Glove box removal
Old Apr 28, 2006 | 04:42 PM
fastevo03's Avatar
Glove box removal
I am trying to install the cabin filter, do I just pull out the glove box. Seems like the glove box is snap on type and no screw or pin is holding it. Please advise.
I don't want to break anything
Old Apr 28, 2006 | 04:46 PM
AtO-MiX's Avatar
yeah pretty much just pull it out...do it carefully though.
Old Apr 28, 2006 | 04:48 PM
BoostWhore's Avatar
you have to push in on the two pieces that stop it from opening all the way then it practically falls out
Old Apr 28, 2006 | 04:57 PM
PANGES's Avatar
There's a how-to for this... but basically if you open your glove box and look on the left wall of the box, on the top right corner where the stopper is, you can pull it towards you and it'll come lose. Then you just pull it into the glove box through the hole. After that, you just sort of push the right side of the glove box in so it bends a little and the right side stopper will clear the rails and your glove box will just fall right down. Make sure you take everything out of your glvoe box before u do this or else you're going to spill everything. Then you just sort of lift and pull the box and it'll come of the little hinges that it's hooked onto... not screwed in or anything.
Old Apr 28, 2006 | 05:19 PM
fastevo03's Avatar
Tried it and it came off easily...thanks guys
Old Apr 30, 2006 | 07:31 PM
EvoRacer619's Avatar
on the left side knock out the clip holder thing best way not to crack anything
