Compilation Of Evo Problems
Old May 17, 2007 | 03:35 PM
  #46
jbenosa's Avatar
The sunroof motor all of a sudden failed and wouldn't slide the window back to the closed position. I had to muscle it back to the closed position and then disconnect the battery as the sunroof motor kept running but was not grabbing on to anything. It closed for good and a quote the local Mitsu dealership gave me was $200 plus $95/hr for labor.
Old May 17, 2007 | 03:52 PM
  #47
sna08's Avatar
2006 Evo 9 se... 3700 miles...steering wheel peeling and brakes squeeks on and off
that's about it for me so far... car is stock...
Old May 17, 2007 | 04:01 PM
  #48
BBS's Avatar
BBS
2006 purchased 12/10/06. 10,1xx miles and no mechanical problems. Installed an Espelir catback 1k miles ago and Tein Flex's installed right around the same time. and nothing to report. The Momo steering is getting stretch marks everywhere and splitting at the 6 o'clock position. In typical Japanese import fashion, the paint is very thin and soft.
Old May 17, 2007 | 04:07 PM
  #49
emagdnim8's Avatar
Originally Posted by su37su
same here, squeaky Recaros.
I figured out where the noise was comming from on mine..maybe its the same on yours. It is right where the seat belt clicks in. I just oiled up the bolt where it attaches and the squeak went away.
Old May 17, 2007 | 04:14 PM
  #50
ST's Avatar
ST
#1 problem - evo = money pit
Old May 17, 2007 | 04:31 PM
  #51
Bonestock!'s Avatar
2005 VIII w/ 9k miles. 5th gear grind started at 7,400 miles with NO mods. Typical wing clear coat fade. Squeakly glove box as well.
Old May 17, 2007 | 05:03 PM
  #52
turb0z-MR's Avatar
I've got a persistent chirping noise coming from the drivetrain.
DS says it's a squeaky rubber seal on the drive shaft but they won't start replacing drive shafts for a squeaky noise that doesn't occur 100% of the time.
It's a PITA to hear without the radio on, but eventually it'll get worse and I'll get it replaced through warranty.
Old May 17, 2007 | 05:41 PM
  #53
mathgeek's Avatar
05 GSR with SSL:
1. Brakes have been nothing but a headache since I bought the car. Just installed a new set of SP Performance rotors (my fourth set overall) and it's been nothing but perfection since. Of course, my last set of rotors (~$1000) were installed backwards by the brake shop and ended up warping beyond hope.
2. Squeaks and rattles ad infinitum.
3. Notchy shifting with occassional grinding of gears.
Other than that, the car has been wonderful (and I'm pushing 60,000 miles). No other issues, and I'm still on the stock clutch.
Old May 17, 2007 | 10:17 PM
  #54
Coprocephalon's Avatar
• With 23K on my '03, I'm on my 4th wing. The dealer replaced it twice for clearcoat issues and I replaced the last Big Wing quickly with an '04 Lancer wing. I'm keeping the CF wing in the garage for when I sell the car.
• The dealer also replaced the Brembos for peeling clearcoat.
• The paint pretty much sucks.
• Plenty of interior rattles.
• My favorite was when my rear window exploded while I was just driving along. It was completely, evenly granulated, with only the tint film holding it together. The sound it made when it failed scared the crap out of me! The dealer replaced it, but I've never used the rear defroster again.
I've heard a lot of bad things about dealerships, but mine has been great.
Old May 17, 2007 | 10:19 PM
  #55
SteelEvo's Avatar
55xxx no probs except for the 4th to 5th gear grind and crappy paint thats chipped like crazy on my front bumper
Old May 17, 2007 | 11:00 PM
  #56
mohseen87's Avatar
06 MR
my cd player is effed, track 6 or 7 on every CD doesnt play...
Old May 18, 2007 | 04:37 AM
  #57
joey0480's Avatar
05 VIII with 10K miles. Somewhat squeaky brakes, weak paint, EXPENISVE
Old May 18, 2007 | 08:24 PM
  #58
lemmonhead's Avatar
Evo 9, 9,000 miles. Starting around 2,000 miles, would get a grind feeling during hard right or left turn. Dealership said its normal from the type of differentil. I had to pay 100 bucks at around 7,000 miles to change all 3 differential fluid. MAGICALLY the grinding dissapeared. (lazy dealership)
Drivers window button gets sticky, Afraid one of these days it will rain and I wont be able to roll up the window. Im to scared to try to get the dealership to fix it. I will wait unitl its dead before they touch it so they dont screw up anything else.
Found Oil dried spots on intake manifold, some kind of leak the dealership must have seen and fixed it.(factory mess up i guess)
hose clamps come loose even from stock boost 19psi. (should have come stock with t-clamps).
Old May 19, 2007 | 01:12 AM
  #59
EVO8URV8's Avatar
Originally Posted by mathgeek
05 GSR with SSL:
Wow, 60k already on 05
Good thing is that ur still on ur stocker at 60k, while I need to replace mine already (I'm barely gonna hit 20k)
Old May 20, 2007 | 07:01 AM
  #60
PantherVIII's Avatar
05 Evolution VIII - Sunroof all of a sudden got off track. I am at 21000 miles with apexi exhaust
greddy BOV
greddy turbo timer
greddy boost controller
Injen Intake
no issues
