Compilation Of Evo Problems
Old May 20, 2007 | 07:15 AM
  #61
3000ways's Avatar
06 EVO IX RS 31K miles
Not many problems, not much I can blame on the car, just had some bad luck. Only really annoying problem is the intercooler hose popping lose, I mean I have had it happend like 6 times and it always happend at some of the worst possible moments, luckly it is a really quick fix and I am back on the road in about a couple of minutes.
Positive things-
Over 50 1/4 mile drag strip hard launches and over 300whp and 31,000 miles and still stock clutch. Although it is starting to slip, but I seriously did not expect it to last this long.
No major mechanical problems, everything is working fine. Although I do need to do my 30k service soon.
Old May 20, 2007 | 08:00 AM
  #62
MR. EVO MR's Avatar
so for with 11800 miles on my 05 MR no problems at all except front drivers side tire side wall is wearing off on top, all other tires have even wear.
I did autocross two times, never launched.
Old May 25, 2007 | 12:40 PM
  #63
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
At about 80k miles, I think my starter is going out. Occassionally when I turn it over, it only clicks. If I try it a few more times, it solves the problem. Clutch went at 50k miles, but only after over 50 launches and a bunch of low 12 second, high 11 second passes. Also, engine damper wobbles like crazy.
Old May 25, 2007 | 06:53 PM
  #64
fueler11's Avatar
A friends 03 has the clear coat problem on the calipers. My 06 MR with 400 miles has a few interior rattles that are worse depending on the road.
Old May 26, 2007 | 10:09 AM
  #65
MirzaJinnah's Avatar
Old May 26, 2007 | 10:11 AM
  #66
Originally Posted by TurboRush
5k, needed a new rear diff. Factory defect, replaced under warranty. Dealer said it was the 2nd one they had seen with the same defect.. factory defect doesn't really count as a problem to me..
I think I may be having similar problem at 3,500 miles. I can hear it when I am slowing to a stop ...its a low hum.
Did you notice it before it failed
Is this low hum (even in neutral) common??
Old May 26, 2007 | 10:29 AM
  #67
The Mitsubishi dealership where I bought my IX a few months ago is gone! CLOSED!
Thanks for the letter (they did not send me) explaining what th hell was going on.
I guess I will have to find one in another city if my differential goes
Old May 26, 2007 | 03:00 PM
  #68
b00stin evo8's Avatar
Originally Posted by B4IFLY
Speeding ticket.
one of the worst reported problems!
Old May 27, 2007 | 11:30 AM
  #69
JDMCT9MR's Avatar
My brakes started squeaking aroung 3,500 miles.Had the rotors resurfaced and it only happens sometimes.I now have this strange crackling noise which seems to be coming from inside the car.It sounds like it may be coming from under the dash.I also had the same problem with the steering wheel peeling at the bottom.Also my steering wheel was off center when I bought it new but by the time I decided to take it to the dealer I had already lowered the car.Other than that its fine.
Old Sep 19, 2012 | 03:50 PM
  #70
connor4200's Avatar
at 53k with 375whp 352wt/q spun the wheels in second couple times lol on damp roads and now i have a scratchy grinding sound during cold start but when its at running oil temps 60-70c it starts fine??/?????/????
neuralcj
Jan 7, 2018 02:50 PM
McSlides
Aug 3, 2012 07:32 PM
LakerRaider
Mar 29, 2009 09:42 PM
2StepsAhead
25
Dec 11, 2006 11:50 PM
Rod Munch
23
Mar 16, 2006 08:37 AM
